Another QTP catted y.......
I just had my longtubes and catted y professionally installed 1 1/2 weeks ago and one of the cats just brushed against my driveway and now its spent, Ive put a whole 200 miles on the car and Im kind of upset. Im going to have to get a custom y made. My question is should I get a new magnaflow/carsound cat and use the other one thats still good, or get some random technology, or better yet magnaflow ultra flow metalic cats if they come out this week
I dont want to pay to get a custom y all fabbed and welded up and then have another cat failure cause then Ill really be pissed, so what do you guys recommend?
I gave up on those cheap magnaflow cats and run no cats right now and have more ground clearance to boot.
Well I spoke to Barry at Qtp and he said he would take care of me, send me out a new cat today
He was a great guy to talk to and really helped me out, He stood behind his product even though the cats arent his. So hopefully I can get it on a lift this afternoon and see what can be done.
If you want cats I would invest in some random tech or the higher quality metallic magnaflow/carsound ones. The cheaper magnaflow/carsound are cheap for a reason.
I got my new cat today, Im bringing it in tomorrow to have it welded in and were going to cut the welds and adjust the driver side up as high as we could without having clearance issues with the floor board. I really hope this new one doesnt go bad for no reason. I saw a sweet setup on here where someone used rt 70000 cats and had then custom installed them. I would like to do something similar but nobody in my area has a mandrel bending machine
So I can still use the great flowing y pipe, flowmaster merge, and cats it just needed some fabricating to make it work in the real world. Trending Topics
Either way, I went through two sets and it really pissed me off. All four cats were rattling around inside. They didn't break up at all, they just came loose from the sides of the enclosure. The Best V8 Stories One Small Block at Time
Is it a pain to get to fit right? Yes
Did it fit right the first time? No
Will it fit right with some work? Yes
Have I installed more than one, or do I do this for a living? No
How is the ground clearance? I have determined that with proper adjustment the ground clearance is comparable to stock. You must note that stock clearance sucked. I had many more scrapes on the ovaled stock y pipe than on my qtp y. I have over 15k on the qtp.
Will I clear all speed bumps and odd driveways? No, but you would not with the stock system anyways. My car is lowered 1" and I can clear most speed bumps.
If I were to do it over again I would likely go with with a custom 2 1/2" Y. With my setup I don't think a 3" y is needed.
Good Luck!!
I was looking at those cats also, theyre really nice, also pricey. If I have another failure with my current ones Ill probably get those or the randon techs. Good luck and let us know how you make out.
Im going tomorrow so I'll let you know how it went. I think my driver side cat is gone because at WOT, It sounds like its kinda like whistling. I dont know.... Hopefully not.... As I know QTP wont replace it if its a little scraped.
