Worth buying air tubes for 2000 mac install?
Old Jan 13, 2003 | 11:58 AM
TaTommyWS6's Avatar
Default Worth buying air tubes for 2000 mac install?
I am going to be installing a set of Mac headers on my 2000 TA. The air tubes on the 2000 do not fit the mac headers.
I have read somewhere that one guy bent the old tubes to make it fit.
I already purchased the correct EGR tube, but I would hae to spend ~$100 on air tubes if I can get away with bending the current ones. Are the tubes easy to bend? Any special tools needed? Any thoughts.
Thanks.
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 13, 2003 | 01:13 PM
black00WS6's Avatar
Default Re: Worth buying air tubes for 2000 mac install?
yea, they're easy. Just put them in a vice and bend. I'd just take them off though. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 13, 2003 | 08:54 PM
1/4master's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by black00WS6:
<strong> yea, they're easy. Just put them in a vice and bend. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i'm going to be doing this in the next week, i'll post on how easy/hard it was.
Old Jan 14, 2003 | 05:07 AM
akaceril's Avatar
the driver side egr tube is a PITA. unless you have a vice, the other side will be too.
Old Jan 14, 2003 | 07:15 AM
robertbartsch's Avatar
Hey:
..just a thought ....You may want to try heating the pipe with a propane blow tourch before you bend it. ...this works for bending a copper tube plumping ...so it should work here...
Old Jan 14, 2003 | 08:27 AM
TaTommyWS6's Avatar
I ordered the correct EGR tube, I just have to worry about the air tubes.
Silly question:
Am I going to simply "twist" the tube 90 degrees?
or
Should I "bend" a 90 degree elbow into it?
I hope that question makes sense!
I am asking becuase I wonder if "twisting" it to fit may snap the tube.
Thanks!
Old Jan 24, 2003 | 10:26 AM
1/4master's Avatar
Old Jan 26, 2003 | 09:32 AM
1/4master's Avatar
for anyone else wonderring about bending AIR tubes, i just did it and it's easy. slap those rascals in a vice, 90 degrees of turn and that's thats. i think that they kind of twist and bend at the same time.
Old Jan 27, 2003 | 08:07 AM
Since we have had a break in the cold weather, I assume those MACs are fully installed....
WOW - It must be intimidating with headers, no cats and a loud mouth....
Old Jan 31, 2003 | 10:59 AM
kp's Avatar
kp
You can also bend the EGR tube to fit, its corrogated(sp) stainless and it bends pretty easy. I bent mine for MACs and bent it back for the stock manifolds when I took them off on my 2k Z28 - no problem at all <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ January 31, 2003, 11:00 AM: Message edited by: kp ]</small>
Old Jan 31, 2003 | 11:39 AM
TaTommyWS6's Avatar
BREAK IN THE COLD WEATHER?!!? Maybe I should move to your side of Hartsdale <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
