guys that are using the 6 liter block?
Old Jan 13, 2003 | 10:19 PM
Train Rail's Avatar
Default guys that are using the 6 liter block?
everything off the ls1 will bolt on to this with no problems( from the bottom up besides internals) ? is there any problems when installing this motor in the t/a as in motor mounts or anything else? thanx <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 14, 2003 | 01:00 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Default Re: guys that are using the 6 liter block?
You have to drill/tap the block for the top alternator bolt. There will be only 2 alternator bolts used instead of the 3, but 2 will hold it plenty (there is no 3rd hole on the block, its the shortest bolt on the alternator bracket). The battery ground hole is not above the starter like the aluminum block is, but you can use a nearby motor mount bolt for the ground. Pretty much bolts in though otherwise.
Old Jan 14, 2003 | 08:36 AM
Train Rail's Avatar
thanx
