Need help: Dealer prodding around
I got a phone call last night (about 8PM) several hours after dropping the car back off at the dealer.
Apparently it was suggested that I have/had a supercharger on the car <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> I was being asked about my ASP Crank and Alternator pulleys as well as the cutouts on the car.
I am worried they are starting to look for anything they can to deny working on my car again (since they cant get it right to save their life).
I obvioulsy never had or do not currently have a supercharger (or nitrous as they had insinuated before also) on the car.
But what problems could the pulleys and/or the cutouts cause me? What could they say? What could I counter with?
Anything would be appreciated - thanks.
Atleast this is what my lawyer friend suggests.
But my quesiton is - what problems could they argue that the pulleys or cutouts are causing. What are some valid issues they can say they lead too and what arent?
BTW - one cutout is located right next to the muffler (horrible location and has been capped for the last 10K miles). Other one is right before the bend over the rear axle. So it shouldnt throw any codes. It has been on the car for about 10K miles and never caused any codes before.
for torque / field current at the
alternator. So you might have trouble
getting the alternator replaced if its
regulator burns up, etc.
Same deal on water pump, you run it
slower, any cooling related beefs you
might expect some resistance over.
Then there's the occasional pulley imbalance,
some folks see this manifesting as knock
sensor false trigger / knock retard, but
a defective pulley that's bad enough to
set this off, may also be doing a bad job
of damping crankshaft vibrations, might
be crank or bearing issues there.
Basically, the dealer made his money when
you bought the car, anything he fixes now
is just a loss. If he's luck, his uncle GM
or the warranty company eats it instead.
But that glad showroom hand stays in his
pocket, when you're in the service bay.
