38lb injectors too much for 422???
Old Jan 15, 2003 | 09:51 PM
theblur98ss's Avatar
Default 38lb injectors too much for 422???
I've been planning on getting 36lb injectors for my 422 buildup. I don't see many of them for sale but it seems that 38lb's are fairly common. What are the downsides(or upsides) to using a bigger injector. I think I read where colonel ran 50lbers on his 422.
Old Jan 16, 2003 | 07:05 AM
2001 Pewter WS6's Avatar
Restricted User
Default Re: 38lb injectors too much for 422???
Brad, you can run them with no problem. You need custom programming or LS1 edit to compensate for them though. I think you can vary 2# either way with stock programming so by going to 38's you will need it calibrated. Hope this helps.
Old Jan 16, 2003 | 06:56 PM
WILWAXU's Avatar
https://ls1tech.com/ubb/ultimatebb.p...;f=24;t=005987
