Damn pcv valve....
Old Jan 16, 2003 | 01:03 PM
OneQuickSS's Avatar
Default Re: Damn pcv valve....
Its on the passenger side of the motor. If you look at the valve cover you will see the rubber hose run all the way from the back, up to the side of the intake. It will have a ground to the motor. Hope that helps.
Old Jan 16, 2003 | 01:07 PM
OneQuickSS's Avatar
You cant miss it, its the hoses right underneath the bracket for the throttle and cruise cable. Its the one that goes into the intake, not the throttle body.
Old Jan 16, 2003 | 01:23 PM
jimmyblue's Avatar
Moderator
It's kind of hidden inside the fat hose that
comes in right behind the TB on the intake.
Old Jan 16, 2003 | 01:39 PM
SixSpeed's Avatar
http://www.installuniversity.com/ins...valve_swap.htm
Go there. I know it's for a 99-00 but it should give you an idea of what to look for.
Old Jan 16, 2003 | 10:58 PM
felton316's Avatar
Its in the black hose on the passengers side. Follow the hose from the front of the motor alnog passengers valve cover, when the hose looks like there is something in it, thats where it is. It looks like a snake (black hose) that has eaten a mouse(PCV valve). Thats how they did it on the 98's.
Old Jan 17, 2003 | 12:14 AM
jpz28's Avatar
Default Damn pcv valve....
Where the hell is it?...i know its on pass. side near the intake but where?...i already have the new pcv valve but either I ain't looking right or something because I can't seem to fin it?...help...where is it specifically?....btw..its a 98Z!!!thanx!! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
