Anyone know how......
Old Jan 16, 2003 | 02:46 PM
sconnor's Avatar
Default Anyone know how......
to set the TPS. My car is surging and I want to check and make sure that the TPS is set at the correct voltage. Also What is the correct V??? TIA.....Scott
Old Jan 19, 2003 | 03:24 AM
J. Larsen's Avatar
Default Re: Anyone know how......
You can't really set the TPS. You will need to back probe the v-ref wire, and put one lead to a known good ground. Voltage at idle should be less than one volt, and at wide open throttle around 4.5 to 5 volts.
Old Jan 19, 2003 | 08:09 AM
unit213's Avatar
Administrator
WOT is 4.7v. You should be somewhere around 4.65 to be on the safe side so you don't throw a code.
