MAF screen removal. Is the only way to cut?
Old Jan 18, 2003 | 02:57 PM
Bill00Formula's Avatar
Default MAF screen removal. Is the only way to cut?
I was thinking of going back to the stock MAF (based on recent posts in the computer section). I was told that all you do is take an exacto (sp?) knife and cut it out. Is the only / best way.
Thanks,
Bill
Old Jan 18, 2003 | 03:02 PM
Tim 98z's Avatar
Default Re: MAF screen removal. Is the only way to cut?
I just used a scribe (hooked like end) slipped it through the hole and yanked it out. About 30 sec to do.
Old Jan 18, 2003 | 05:56 PM
unit213's Avatar
Administrator
I used a screwdriver.
Old Jan 18, 2003 | 07:02 PM
jimmyblue's Avatar
Moderator
Remove the end. Put 1/2" of liquid-type
(not the jelly type) paint stripper in
a dish. Set the end in there, screen down,
overnight. Cover with aluminum foil.
Next day, the epoxy the screen's bedded
in will be softened, and you can run an
X-acto between it and the body, the whole
thing will come out intact if you're neat.
This way, you can put it back in again if
you choose with a little JB. When I got
mine out it was still clean & tight enough
that it would stay in by friction when I
put it back (just playing). I did this on
a used MAF I got pretty cheap ($40 I think).
Old Jan 19, 2003 | 02:41 PM
MechMan's Avatar
Bill you just push it out with a screwdriver.
Takes 10 seconds
Old Jan 24, 2003 | 10:47 AM
Chivalry101's Avatar
When I did mine, all I did was take the MAF apart and pushed it out by hand.
Old Jan 24, 2003 | 09:28 PM
Thanks for the info.
