Anyone run open T.B.?
Old May 23, 2006 | 11:35 PM
CMKworm's Avatar
Question Anyone run open T.B.?
Mine is a street car but only driven on occassion. I was wondering if there was any benefit from running the throttle body open with only the MAF in front of it(no air filter or intake). I ran it like this for awhile but is this a good idea?
Old May 23, 2006 | 11:52 PM
FrozenMonkey's Avatar
Don't see the point in this, unless you really want to have tons of dirt in your engine.
Old May 23, 2006 | 11:56 PM
02TransAm/Batmobile's Avatar
what the hell are you talkin about?
Old May 24, 2006 | 12:00 AM
SSilverSSurfer's Avatar
all i have is the filter in the airlid....when i did the Speed density tune you pretty much delete the maf...so filter in front of the throttle body is basicly what im running
Old May 24, 2006 | 12:03 AM
CMKworm's Avatar
what I'm talking about is having no intake all the way back to the maf.
Old May 24, 2006 | 12:07 AM
ohh, . . you mean basically takin off your airlid and runnin with that, right? . . . i misunderstood and somehow thought you mean runnin with your throttle body plate open, . . . . . to answer your question, . . . thats what the filter is for, . . keepin debris and stuff out of your engine, . . . i'd suggest jus runnin with a k&n filter cone, . . it looks stupid and ricer but that's as close as you'll get . .
Old May 24, 2006 | 12:08 AM
Gearhead1's Avatar
I don't understand the reasoning (or lack of it) behind your decision. Don't do it!! As large as the LS1 air filters are, they pose no restriction. Even the stock paper ones aren't restrictive. Oh yeah, did I mention, don't do it!!
Old May 24, 2006 | 12:10 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Put the filter and stuff back on. It is not a really good idea if you ask me.
Old May 24, 2006 | 12:11 AM
i wouldn't go that far Gearhead, . . . i've heard of people pickin up a 3-4 horses dynoing without the filter, . . jus airlid, . . without the filter its more flowing but not worth killin your engine for 3 or 4 horses, . . they're restrictive but very minimal
Old May 24, 2006 | 12:29 AM
Gearhead1's Avatar
Now you've got me curious. I'd like to bear witness to a dyno run that would prove or disprove that. I was always under the impression that it wasn't a restriction. My sons car showed no improvement at the dragstrip after removing the K&N filter from it's housing. But then again, 3 or 4 HP wouldn't really show up at the strip. (unless your car was extremely consistant)
Old May 24, 2006 | 12:34 AM
Ferocity02's Avatar
The intake in any car not only serves to clean the incoming air, but it also helps to straighten the air flow to make it more laminar. Turbulent flow cannot go as fast as laminar efficiently. Running an open MAF will probably not show that much of a gain, and you will be sucking **** into the engine.
Old May 24, 2006 | 12:37 AM
99camarols1m6's Avatar
with the maf right in front of the TB with nothin in front of it when you get goin fast enough there will be some wind turbulence inside the engine compartment itself that will blow air across the maf and screw up its readings... another downside. just take the filter outa your lid if you really have to.
Old May 24, 2006 | 12:38 AM
383LQ4SS's Avatar
I had a custom 3.5 inch tube intake wih dual K&N cone filters with speed ensity tune...no maf. FAST 90 mm intake.TB. I dynoed with the open TB and lost about 5 peak hp and a TON under the curve. It was a 415 making about 560 rwhp NA though.
try blowing into your maf when the car is running and see what happens lol
Old May 24, 2006 | 12:51 AM
Gearhead1's Avatar
My wife blew into my MAF tonight, it made my eyes roll back in my head!!
staringback05's Avatar
WTF to this thread?....
Old May 24, 2006 | 02:35 AM
OUTLAWZ RACING's Avatar
WTF
Old May 24, 2006 | 09:22 AM
CMKworm's Avatar
I won't try it! Thanks!
Old May 24, 2006 | 05:59 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
Originally Posted by OUTLAWZ RACING
WTF
Old May 24, 2006 | 06:56 PM
Asmodeus's Avatar
when people pick up HP on the dyno with no filter, they generally have the hood open with a big *** fan blowing into it. running with an open TB on the street would just increase IAT's and be counterproductive of less restriction..
