How long would it take to install hooker LT and Y
Old Jan 19, 2003 | 10:47 PM
LTHL SS's Avatar
Default How long would it take to install hooker LT and Y
What tools do I need and tricks to get the job done quicker?
Old Jan 20, 2003 | 03:09 AM
BADFNZ's Avatar
Default Re: How long would it take to install hooker LT and Y
Well if its your first time to install headers like it was mine, itll take about 10-15 hours <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> Be sure to have a full metric socket set and wrench set. The only standard wrench you'll need is a 7/8 (I think) for the O2 sensors. You'll need a jack and jack stands and anti-seize for the header bolts. And get new oem header gaskets from a GM dealer. Don't use the Hooker ones. That's all I can think of at 3:05am. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 20, 2003 | 01:09 PM
MOBE's Avatar
The first Hooker install I did (on my car, with the help of a friend) took 14 hours. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
The second Hooker install I did (on friend"s car) only took 5 1/2 hours! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 20, 2003 | 05:39 PM
M3EATER's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MOBE:
<strong> The first Hooker install I did (on my car, with the help of a friend) took 14 hours. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
The second Hooker install I did (on friend"s car) only took 5 1/2 hours! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">5-1/2??? No Fair, your friend was helping !
8 hrs is the fastest I've done from pulling the car in to rolling it out ... for headers & Y.
Good Point on the spark plugs..... have a fresh set to swap in while the manifolds are off. AND, if you got higher mileage OR just want to upgrade.. NOW is the time for wires !
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Gordon
www.provenperformanceconcepts.com
<img src="http://www.provenperformanceconcepts.com/PPC%20BANNER%20468x60.jpg" alt=" - " />
Old Jan 20, 2003 | 06:25 PM
MOBE's Avatar
I **** you not! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
We (me and Slow Z28) Started at 8:30 on a Friday night and stopped around 12:30. Our goal was to just get off the stock garbage, and then finish in the morning. After about 2 hour we had the manifolds & y-pipe off, the steering linkage off, and so on. We were making such headway we decided to keep going. By 12:30 we had the driverside done (including new spark plugs), and the passengerside bolted up. In the morning we put the new plugs in the passengerside, put the y-pipe on, and hooked the AIR & EGR up in about an hour and a half. <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Jan 20, 2003 | 06:48 PM
deviate42's Avatar
it took me 5 1/2 - 6hrs for Grotts. It depends if you are somewhat pointed in a direction andif you have the tools right there handy. If you have to look for tools, or have to call poeple up to ask what to do next, it will take longer.
id advise to have someone help you. I had just one of my friends who did nothing but either hold things in place, or hand tools to me. It was a huge help.
Old Jan 20, 2003 | 06:52 PM
deviate42's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LTHL SS:
<strong> What tools do I need and tricks to get the job done quicker? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">..a lift <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 20, 2003 | 07:33 PM
FAST LS1's Avatar
I have a ramp, so my car was about 5.5ft off the ground for the install <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> The only bad part was I had to stand only on the 2 sides of the ramp when working on top in the engine compartment <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> From start to finish it took about 13 hours. 4-5 hours of that was in the dark while it was raining, another 1-2 hours was fooling with the AIR and EGR tubes. I reworked my stock 2000 tubes to work on the 2001+ Hooker headers. Do as everyone has said, take off everything, the coil pack, the oil diverter plate, and the steering shaft. I reused the stock gaskets, and put new plugs in since they had to be taken out anyway. Good luck and wear some gloves, I came away looking like I'd ripped out a thorn bush by hand when I was done. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 21, 2003 | 12:34 AM
2002blackZ's Avatar
It took me about 15 hours. I did piddle around a lot. Did it all by myself. I spent a couple of those hours messing with the AIR Tubes. (I put 98-99 Hooker headers on a 2002 Z) I reused the stock gaskets as well.
Best advice I can give. Take your time and remove all the parts you need to. (steering shaft, oil diverter, and coil packs.) You'll need to remove the spark plugs as well. Take off the wires while your at it. It gives you more room. The higher you can get your car the better. I had the rear tires on ramps and the front on stands. I had to jack up the passenger side to get the header in though. Then put it back on the stands to finish up. You will also want to loosen up all the manifold bolts before you get it up in the air.
Have fun. They are worth the effort!
