throttle body question?
Old May 24, 2006 | 07:02 PM
STRETCH'S T/A's Avatar
Default throttle body question?
can you remove the 2 coolant hard lines that attach to the throttle body? did the tb bypass mod, and don't like the look of the caps on the tubes under the tb. just wondering.
Old May 24, 2006 | 07:07 PM
RrCoX22's Avatar
a little confused on the question... you need to either have the caps on or the ports tubed over, whats wrong with having the caps on?
Old May 24, 2006 | 07:12 PM
motoxlifer's Avatar
I don't think it will hurt. Since it is a water only passage you won't get a vacuum leak or anything.
Old May 24, 2006 | 07:17 PM
don't like the looks of the caps on the tb, think it would look better and cleaner without those 2 hard lines coming out of the tb.
Old May 24, 2006 | 08:37 PM
yak's Avatar
yak
just cut them off and use epoxy to cover the holes.
Old May 25, 2006 | 12:21 AM
Shallow Bay's Avatar
I believe they just pull out.
Old May 25, 2006 | 02:32 AM
staringback05's Avatar
dremel them bitches...cmon
Old May 25, 2006 | 04:01 PM
Bo White's Avatar
Just pull em out, no need to plug em off anyway. Ive even cut the line boss down smooth for a couple of guys. Its just an in and out on the coolant on the bottom, you do the bypass- no need for em anymore.
Old May 25, 2006 | 05:09 PM
Iron Sights's Avatar
Old May 25, 2006 | 06:03 PM
thanks everyone for the input, i will be pulling them out this weekend.
