Anyone interested in pre-made true dual setup?
There are a few things that would be a must for me to buy a dual set-up...
Mandrel bent. (of course)
At least 2.5" pipes. (Maybe 3" to the axle and 2.5" afterwards)
Both pipes traveling down the right side where the I is stock.
The over axle pipes both going over the right side of the axle.
The tail pipes centered perfectly. (most exhaust systems have off center tips for some reason... I had an exhaust shop center mine perfectly)
My .02
Dave
Dope
Ratio411's comments were good; also thing about SFC's...most modded cars run a SFC which may have different routing issues if they are the DD or SLP type. Same for Drive shaft loops. Last thing would be a x or h balance pipe built in.
Keep us posted here.
1. the ability to connect to LT headers (FLPs)
2. the ability to put in some small Muffs after the axles, right before the tips...
3. pipes at least 2.75 inch diameter....
<strong> Make a 3" mandrel bent over the axle and I will buy it. Has to have an X-pipe. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Amen,
I would even just pay for the 3 inch mandrel bent tubing with Xpipe and put whatever mufflers I wanted in the package (XR1's, Bullets, XS etc.)
Cheers,
Chris
Over the axle is a whole new ballgame, and not easy - but possible.
Our web-site has pics and sound clips in the Performance section under F-bods.
We use Dr. Gas junctions and all mandrel bends.
<strong> Lane did you route both pipes over the axle on one side or split them and remove the upper PHR?
Justin </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We split 'em. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Check my pics in the thread about duals over the axle.
Cheers,
Chris
<strong> I am definitely interested in dual over the axle setups with X-pipe. It MUST be three inch mandrel bent though. Where have you been putting the mufflers?
Cheers,
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">that's what I want too! very interested
I want 2.5" mandrel bent over the axle, both on the same side as stock and then mufflers before the tips.
Maybe the best thing to do is sell the system without any mufflers and let the installer splice in the mufflers? That way you could do bullets or regular mufflers.
Chris
no worries <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> they would have to go over axle though, all that sound right under me might be a little too loud....
Amen,
Yup!
