Stepped headers results
Old Jan 25, 2003 | 10:18 AM
Futral's Avatar
Default Stepped headers results
Swapped out my Grott 1 3\4" stright headers for the headers I modified for GTS-SS, 1 3\4" - 1 7\8" stepped headers. He is no longer needing then with the bigger motor <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
NOTE:the results are through a 12-bolt with 4.30's,22lbs chromemoly driveshaft,stock SS wheels with drag radials. <img src="http://members.***.net/jason99ta/FMSstepped_vs_grots.jpg" alt=" - " />
Old Jan 25, 2003 | 10:34 AM
Gary Z's Avatar
Default Re: Stepped headers results
I may be wrong but I suspect that not all variables except headers were held constant between these runs. How does an improved exhaust system produce such uniform results across such a broad range? I would expect any improvement to appear mostly at the upper end. On the other hand, my engine doesn't go that fast.
Old Jan 25, 2003 | 10:58 AM
Futral's Avatar
The stock LS6 intake is restricting the upper RPM power potential. Dynoed 475rwhp with the 1 3\4" headers and my prototype sheetmetal intake, made that at almost 7400 RPM.
What was nice,it dynoed an even 500rwhp uncorrected.
This motor in a stock drivetrain car would make close to 500rwhp CORRECTED <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 25, 2003 | 02:42 PM
John B's Avatar
Moderator
Welcome to the "stepped" header club Alan with a properly designed step! Very nice results. Are you also using a true merge collector too?
Old Jan 25, 2003 | 03:37 PM
Fenris Ulf's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by John B:
<strong> Welcome to the "stepped" header club Alan with a properly designed step! Very nice results. Are you also using a true merge collector too? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">He has a straight collector on it, unfortunately no one sells a cheap merge for our cars.
Awesome results Allan!
Old Jan 25, 2003 | 03:39 PM
Fenris Ulf's Avatar
Oh yeah, is the passenger side header phased correctly now or in the same firing order grot had it?
Old Jan 25, 2003 | 05:31 PM
Futral's Avatar
The pass header has the same phasing as the original Grott design.
Old Jan 25, 2003 | 05:32 PM
GrannySShifting's Avatar
I cna see some places where that motor could use soem help looking at that graph <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 25, 2003 | 07:53 PM
Jason99T/A's Avatar
I can shift faster than you.
Very nice #s Allan! Get the new and improved intake on there and an electric water pump and I can see close to 500rwhp through your un-dyno friendly drivetrain. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Jason
Old Jan 26, 2003 | 01:00 PM
JS's Avatar
JS
Dyno numbers are skewed and the HP/TQ peaks are way off.....5250 rpm is where its supposed to be alan?
JS
Old Jan 26, 2003 | 02:05 PM
Futral's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JS:
<strong> Dyno numbers are skewed and the HP/TQ peaks are way off.....5250 rpm is where its supposed to be alan?
JS </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> OK JS , LOOK at the scaling,if will make you happy I can get Jason to rescale it for you <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
And whats wrong with my my peak torque at 5500 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 26, 2003 | 02:41 PM
Fenris Ulf's Avatar
JS </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Its called scaling <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Haha, just had to bust your chops JS, no harm intended <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 26, 2003 | 10:42 PM
JS's Avatar
JS
U got me Fernis
Alan just wanted to hear the reason buddy.
No harm done <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
JS
Old Jan 26, 2003 | 11:09 PM
Futral's Avatar
<strong> U got me Fernis
JS </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No problem, I knew you were just curious <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 27, 2003 | 10:32 PM
John B's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">unfortunately no one sells a cheap merge for our cars </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not true! And I assume you mean inexpensive....not cheap! I got my merge collectors in mild stell for less than $150 for the pair and the quality is very nice!
Old Jan 28, 2003 | 09:22 AM
Black Sunshine/ 00SS's Avatar
I assume this was on a 346? I'd like to know if there would be any benifit on a 393 all bore?
Old Jan 28, 2003 | 11:22 AM
Fenris Ulf's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black Sunshine/ 00SS:
<strong> I assume this was on a 346? I'd like to know if there would be any benifit on a 393 all bore? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That was on a 346 but I believe the benefits would be even more pronounced for a larger bore motor.
