Hooker Header o2 sensor Clearance issues
Old May 29, 2006 | 09:36 AM
Toxic_WS6's Avatar
Default Hooker Header o2 sensor Clearance issues
Anyone have clearance issues with the o2 sensor? I raised the fuel lines and cut the heat shield. Not sure if this is enough.
Attached Thumbnails Hooker Header o2 sensor Clearance issues-o2-1.jpg   Hooker Header o2 sensor Clearance issues-o2-2.jpg   Hooker Header o2 sensor Clearance issues-o2-3.jpg
Old May 29, 2006 | 01:53 PM
TheBlurLS1's Avatar
That's what she said...
Hopefully It will be, not a whole lot you can do now. Why didn't you get the Pacesetters where they put the O2's on the CORRECT side? There's a reason why 500,000 people recommend them for anyone looking for mild steel headers.
The only thing you can do is try to keep the wires from getting burned.
Old May 29, 2006 | 02:12 PM
oange ss's Avatar
i moved mine to the inside and use the outside ones for my wideband
Old May 30, 2006 | 11:29 AM
SS1875's Avatar
I had the same issue...all I did was cut the heat shield and folded the tab away from the sensor, it worked out okay for me. Yours seems to be a bit closer than mine was though. Hope it works out for you,
Old May 30, 2006 | 11:42 AM
12secSS's Avatar
Mine have been on my 2001 Camaro SS for over 4 years, no problems at all. I do not like the setup pioneered by Jet-Hot (O2 on the inside). Your harness will be fine with what you did to clear them, hell I did not even cut my sheild, nor relocate the fuel lines.
Old May 30, 2006 | 04:26 PM
Toxic_WS6's Avatar
Thanks, will keep you posted.
