What other bolt ons can i do?
Old May 30, 2006 | 07:02 PM
03 BUSA's Avatar
I agree with starting the suspension mods now. You are just about done with the bolt ons and if you plan on doing internal stuff later you could be wasting money on bolt ons that you will upgrade later to go with the internal stuff. Just my .02
Old May 30, 2006 | 08:25 PM
slowpoke96z28's Avatar
you'll see a gain with an UD pulley.
Old May 30, 2006 | 10:14 PM
ChocoTaco369's Avatar
Tech Resident
get a blower. that's a bolt-on right you're not touching internals...
Old May 30, 2006 | 11:17 PM
c0ncEpT's Avatar
A 3800+ Stall would really show the potential of your car
Old May 30, 2006 | 11:50 PM
TheBlurLS1's Avatar
That's what she said...
Originally Posted by Brian2006
i hear that the undrive pulley is a waste of $200 bucks. is this true? My MAF is descreened btw.
Pulley is a good mod, usually people save that one and do it along with a cam because the pulley has to come off anyway.
I agree with getting a stall/tranny cooler if you don't have one. You'll have a brand new car with that installed. Do a little research in the auto trans section.
Old May 30, 2006 | 11:59 PM
Brian2006's Avatar
I do have plans for a stall but as for right now I wanna see the lowest possible quarter mile time with basically cheap engine bolt ons..... also I have a friend that just barely beats me and I wanna get me the next extra pull that I can
what kind of results have people seen with a tranny cooler?
Old May 31, 2006 | 12:05 AM
TheBlurLS1's Avatar
Start taking **** out of your car! Light weight FTW! SUX2BU trapped over 120mph with boltons.
BTW - with tranny coolers, people have seen results of something along the lines of their trannies lasting longer.
Old May 31, 2006 | 12:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by 01bird58
What about a Meizeire (sp?) water pump...
It can be a good one to have if you are idling in the pit area and need to keep your water flowing when the car is off.
Old May 31, 2006 | 12:58 AM
zspot98's Avatar
What about a tubular front K member? And as stated before lots of weight reduction.
Old May 31, 2006 | 01:15 AM
TheBlurLS1's Avatar
I've debated that myself, but I've seen too many failures to run one on my daily driver.
The new Sphon and Umi ones coming out look to be pretty damn stout. BYUNSpeed has emailed me twice about those bitches already. lol
Old May 31, 2006 | 11:44 AM
Brian2006's Avatar
Keep in mind I drive this car every day of the week so I can't do too much weight reduction. So far I have !EGR/Air, !Back Seat, !heat shields and !spare tire/jack. What else can I do away with without noticing anything?
Old May 31, 2006 | 12:32 PM
  #32
zspot98's Avatar
Front bumper support
ABS Delete
Removing A/C (depending on location).
Sound dampening under carpet
Just to name a few...
Old May 31, 2006 | 01:37 PM
  #33
NEED2SPEEDLS1's Avatar
i wanted to take out my back seat. worth it?
Old May 31, 2006 | 01:38 PM
  #34
and def a underdrive pully. its a good mod at a decent price. runnin ASP here
Old May 31, 2006 | 02:45 PM
  #35
Ls1_axxxman's Avatar
Originally Posted by GR33N GoblinM6
start doing the suspension and make that thing handle. poly bushings, LCA's, shocks,
or a pro 5.0 shifter,
I definetely agree there suspension does help. My car is way more responsive, also launches and handles better with what lil susp ive put on mine. Brakes are a damn good bolt on that alot of ppl overlook, was first thing i upgraded on mine.
Old May 31, 2006 | 03:19 PM
  #36
zspot98's Avatar
Weight us weight, I think removing them is worth maybe 40lbs.
