O2 Sensor Bungs?
Old May 31, 2006 | 07:33 PM
ramair21's Avatar
Default O2 Sensor Bungs?
Where could i get some at? I need to cover up the old O2 sensor hole on the passenger side and install the new bung along with 3 others. Just need to know where i could them?
Old May 31, 2006 | 07:43 PM
fast377's Avatar
Internet, parts store, speed shop. Just depends on how quick you want them. I've seen them at a bunch of places. I think the last ones I bought were only around $6 each.
Old May 31, 2006 | 07:44 PM
ZoFastSS's Avatar
Thunder Racing.com, if I remember correctley sells them.
Old May 31, 2006 | 07:50 PM
fast377's Avatar
yep here's the link: http://www.thunderracing.com/catalog...id=223&pcid=54
11th one down
Old May 31, 2006 | 10:44 PM
NviouSS's Avatar
dynotune.com also sells them.
Old May 31, 2006 | 11:05 PM
ramair21's Avatar
Awesome!! But Thunder does not carry a plug to plug up the old hole? But 6 bucks is really cheap. I might have to go with them. But any idea on what to plug up the old hole?
Old May 31, 2006 | 11:07 PM
ramair21's Avatar
Hold on, is the O2 Sensor Plug what i need to cover the old hole? I just saw that right now on the web. is that right
Old May 31, 2006 | 11:10 PM
TheBlurLS1's Avatar
That's what she said...
You can use a damn bolt to plug the hole, or just use an old O2 sensor.
A bung is the metal threaded hole that welds to the pipe.
Old May 31, 2006 | 11:12 PM
ramair21's Avatar
so basiclly i could just get a 18mm nut and make a hole and weld it to the pipe and thats my bung? and just stick a bolt into the old hole and call it a day?? Could i just do this?
Old May 31, 2006 | 11:16 PM
TheBlurLS1's Avatar
You'd have to make sure that the O2 sensor seats well and protrudes the correct amount into the pipe, but it would probably work. O2 bungs are cheap as hell though, I'd just go with that.
The bolt in the hole would work fine, if it falls out, you'll know it.
Old May 31, 2006 | 11:30 PM
ramair21's Avatar
I guess i just go buy some. I really need it, so do you think i could get them at a parts store. I would go with thunder but they charge 45bucks for next day air.
