160 or 180?
Old Feb 16, 2003 | 08:23 PM
TA98's Avatar
Default 160 or 180?
What would be best a t-stat at 180 or 160?
Old Feb 16, 2003 | 09:17 PM
NightHawk's Avatar
Default Re: 160 or 180?
I'm going for a 160, you and I both live in hot climates. It doesn't do a whole lotta good unless your fans are set to come in at a lower temp, because the t-stat will kick in at the lower temp, but the engine will still get to the same running temp with the fans set to the stock temp. Are you planning on doing a fan mod like a switch or custom programming?
Old Feb 16, 2003 | 10:40 PM
Black LS1 T/A's Avatar
Moderator
180 would be a waste of time and not much difference. Adjust the fan temps to accomodate the season.
Old Feb 16, 2003 | 10:49 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
A 180 stat dropped my car about 10* from the stock stat with the same fan settings (custom). I don't like the 160 stat really. Sure, you can set the fans to keep the motor warmer, but if it's cool outside and you're at speed, the motor can easily get down to 170*, which is colder than I like my motor to run. Just my opinion.
