ASP pulley and overdrive alt??
Old Feb 17, 2003 | 10:24 PM
Classic's Avatar
Default ASP pulley and overdrive alt??
Ok here is my question - does going with the overdrive alt pulley kick the alternator back up stock levels?? Also, by going with the overdrive alt pulley how much does that decrease the "underdrive" effect?
Just need some input before my cam install.
Old Feb 27, 2003 | 06:54 PM
Caswell's Avatar
Default Re: ASP pulley and overdrive alt??
Can't really tell you if you'll get back up to stock power levels with the alt od pulley, but my guess is that you will. I don't think you'd give up any power - from what I know of underdrive pullies most of the gains come from slowing down the water pump.
PS. - Keep your head up and don't let Tech beat you down... if I got out anyone can!
Old Feb 27, 2003 | 11:04 PM
LOnSLO's Avatar
You don't need to overdrive the alternator at all. If you're worried about charging power, like me, then just do the crank pulley. You won't even notice the difference.
Old Feb 27, 2003 | 11:11 PM
Classic's Avatar
Good deal. Thanks for the input guys.
