When closed, would cutouts decrease power due to turbulence in exhaust flow?
Old Feb 27, 2003 | 11:51 AM
xxxhp's Avatar
Default When closed, would cutouts decrease power due to turbulence in exhaust flow?
That's what I've heard.
Did anyone dyno his car with no cutouts & then dyno it with cutouts closed? If so, was there any difference?
Old Feb 27, 2003 | 05:19 PM
Old SStroker's Avatar
Default Re: When closed, would cutouts decrease power due to turbulence in exhaust flow?
Closed cutout performance could suffer depending on how the cutout is mounted. However, a typical QTEC mounting as shown in this link
http://www.quicktimeperformance.com/qtec.htm
probably doesn't cause very much disturbance where the cutout pipe y's into the head pipe. It just packs with exhaust gas, and the flow hardly notices. Probably not a measurable hp loss on a chassis dyno.
My larger concern would be the less than optimum path with the cutout OPEN. Here the gas has to make a rather abrupt turn to find the path of least resistance. Lots of gas still goes thru the street portion of the system which is the straight shot.
If I were doing it, I'd place the cutouts where the head pipe turns 90 degrees so that when the cutout was open the exhaust had a straight out shot, and when it was closed it would go out the "Y-pipe". This would require QTEC's without their "Y's" and some fabrication. It there were room I'd probably put turndowns after the cutout also. Both my Chebbies have "true duals" and the Ultraflows (Impala) and Corsas (C5) flow well and sound good to me, so no cutouts.
My $.02
<small>[ February 27, 2003, 05:22 PM: Message edited by: Old SStroker ]</small>
Old Feb 27, 2003 | 05:27 PM
98raregoldws6's Avatar
i gained 11 rwhp on the dyno through my cut out <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 27, 2003 | 07:44 PM
Fenris Ulf's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Old SStroker:
<strong> Closed cutout performance could suffer depending on how the cutout is mounted. However, a typical QTEC mounting as shown in this link
My $.02 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree, the way its tee-d off of the flowtech cutout it will create very little head loss. Probably be less than a smooth 45* mandrel bend would cause, definately nothing noticable at the track or dyno.
Old Feb 28, 2003 | 12:43 AM
FatZ28's Avatar
Good question, I would also like to know?
Old Feb 28, 2003 | 12:52 AM
CamaroSS_2002's Avatar
Theoretically yes, the exaust as it's leaving the vehicle wants to expand cause of heat and take the shortest path possible, when it reaches the cut-out the exaust will expand. and a portion of it will become trapped at the Y part.
Nothing significant but it would create a little more backpressure cause the cooler exaust would slow things down a little.
In a perfect world you would be able to compare the difference, but in our world I doubt you're gonna notice it.
<small>[ February 27, 2003, 12:54 PM: Message edited by: CamaroSS_2002 ]</small>
Old Feb 28, 2003 | 11:15 AM
xxxhp's Avatar
TTT
Old Mar 1, 2003 | 08:54 PM
BADFNZ's Avatar
I was thinking about this exact thing a few days ago. TTT
Old Mar 22, 2010 | 12:46 AM
Engine_HP's Avatar
I think it will couse turbulence, TTT to see what others think.
Old Mar 22, 2010 | 02:47 AM
Soul TKR's Avatar
Really? a 7 year old thread?
Old Mar 22, 2010 | 06:06 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by engine_hp
i think it will couse turbulence, ttt to see what others think.
troll!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 22, 2010 | 07:55 AM
TheSilverOne's Avatar
IBTL
Old Mar 22, 2010 | 08:03 AM
01ssreda4's Avatar
wow......
Old Mar 22, 2010 | 08:17 AM
Johns00Z28's Avatar
It's funny how people always tell others to use the search and when they do they get flak for bringing up an old thread....go figure?
Old Mar 22, 2010 | 10:54 AM
Engine_HP's Avatar
^^^^ im also disapointed, especially from mods who LOCKS threads and tells ppl to use the search.
want some usefull INPUTS.
thanks guyz.
Old Mar 22, 2010 | 11:40 AM
Mart00SS's Avatar
I would say probably wouldnt bee more turbulant than making a sharp turn inside a muffler. I'm sure its more turbulant than a straight pipe, but the affects have to be minimal if any. I felt no difference before and after my cutout install with the cut out closed.
Old Mar 22, 2010 | 01:17 PM
Z28_LT1's Avatar
what about with the cutout open?
