slp pulley?
Old Jun 5, 2006 | 05:51 PM
02 z/28's Avatar
Default slp pulley?
I have a slp underdrive pulley that Iam installing,but I noticed that it has a key way slot but the stock one does not.Is there a certain way it has to be installed?Thanks
Old Jun 5, 2006 | 06:22 PM
Iron Sights's Avatar
Nope, just ignore it. I thought the same thing, but this does not affect how it is installed.
Old Jun 5, 2006 | 06:41 PM
davered00ss's Avatar
Moderator
That is for high Hp applications. NO2, or forced induction. Your crank is not keyed, so you do not need to use it. If you wanted to, you could Key the crank.
Old Jun 5, 2006 | 06:47 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mine is keyed. 400 shot will do that to ya!
Old Jun 5, 2006 | 07:29 PM
02 z/28's Avatar
Thanks for the help,Iam putting the pulley on and hope to start it up tonight,cant wait to hear the f13 come to life.
Old Jun 5, 2006 | 07:32 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Make sure you have a new crank bolt man!
Old Jun 5, 2006 | 08:01 PM
02 z/28's Avatar
One comes with the pulley,but thanks for the heads up.
Old Jun 5, 2006 | 10:30 PM
02 z/28's Avatar
How did you guys get that bolt to torque down to 240lb,Iam using the biggest torque wrench I have should I buy a chearter bar?Thanks for the help
 Michael S. Palmer
Old Jun 5, 2006 | 10:47 PM
618HAWK's Avatar
Put your feet on the left tire or frame rail and PULL.
Old Jun 6, 2006 | 06:23 AM
02 z/28's Avatar
Will do,thanks
Old Jun 6, 2006 | 06:45 AM
LS1Lust's Avatar
How do you guys like the SLP pully, I am trying to decide between that one and the ASP one.
Old Jun 6, 2006 | 08:34 AM
GuitsBoy's Avatar
SLP = powerbond. Its preferred due to the higher walls keeping the belt from jumping off at high rpm.
Old Jun 6, 2006 | 09:13 AM
618HAWK's Avatar
I had no problems with the SLP unit. It was a nice piece of workmanship. Never threw a belt once.
