Porting TB in ILLINOIS
Old Jun 6, 2006 | 03:42 PM
Justin00SS's Avatar
Originally Posted by NoMoreLS1
The stock MAF is fine too... leave it alone. I have seen far too many ported throttle bodies cause problems. Leave it alone. If you have a big cubic inch motor then just replace it with a larger throttle body.
Hit yourself.
Old Jun 6, 2006 | 03:46 PM
Justin00SS's Avatar
Originally Posted by TORCHD 02 TA
did you notice anything when it was ported?
Yes. I swapped the ported one on and I immediately noticed a difference.
My exhaust a little more throaty. I dunno could be just me. But also moving from a stop was alot easier. It wanted to go more. Much better throttle response.
Old Jun 6, 2006 | 03:47 PM
maddboost's Avatar
Ive seen a few ported too much by the blade and it messes up the idle because more air is getting around the outside of the blade. The HP gains are minimal at best on a ported throttle body.
Old Jun 6, 2006 | 03:49 PM
Justin00SS's Avatar
That I believe.
But I have yet to see a bunch of threads about horror stories from porting one. lol
I'm a searching ****.
Old Jun 6, 2006 | 04:29 PM
NoMoreLS1's Avatar
Smile
Originally Posted by TheBlurLS1
All those threads must have slipped through here without me seeing them.
Oh yeah... it wasn't posted on the internet so it must not be true.
I have personally seen a number of cars with ported throttle bodies with nothing but problems. Put the stock throttle body back on and the problems magically disappear.
Old Jun 6, 2006 | 04:39 PM
Bo White's Avatar
They were ported incorrectly, send it to a pro that sponsors LS1TECH if you do not feel up to the job. My link is pretty easy to follow if your a mechanicaly inclined do-it-yourselfer
Old Jun 6, 2006 | 04:58 PM
TheBlurLS1's Avatar
That's what she said...
I guess nobody should put a cam in their car because they might forget to put the timing chain on too? They might also leave a ratchet under the valve cover? Might want to keep away from tires and wheels because you might forget the lugnuts? I've heard changing the oil is bad too because the plug might fall out.
Anything that is screwed up as a soup sandwich is going to have ill effects, this is what we call a given. A throttle body ported CORRECTLY and CAREFULLY is a great mod, which should also be a given.
Originally Posted by Bo White
They were ported incorrectly....
Old Jun 6, 2006 | 05:38 PM
TORCHD 02 TA's Avatar
hey Bo come to chicago and port my TB for me
how hard it is from 1 - 10???
i wnat to do this mod really bad
Old Jun 6, 2006 | 05:55 PM
Justin00SS's Avatar
its not night and day but it is a a worthwhile mode.
Old Jun 6, 2006 | 05:57 PM
motoxlifer's Avatar
I just did mine too and it wasn't very hard to me. Just do like they said and STAY AWAY from the area where the blade seats. I also noticed a nice improvement in throttle reponse. I think it's well worth it.
Old Jun 6, 2006 | 05:58 PM
Justin00SS's Avatar
What does your truck run with the LS1?
Old Jun 6, 2006 | 06:06 PM
  #32
motoxlifer's Avatar
My best so far in the 1/8 is an 8.63. That's with the 20's on it. I think I can get it down to a low 8 with a few minor alterations.
Old Jun 6, 2006 | 09:59 PM
  #33
CRZYPWR's Avatar
Bo White - TB Guru.. mine is goin straight to him!
Go Bo !
Old Jun 7, 2006 | 12:02 AM
  #34
NoMoreLS1's Avatar
I don't know why I even waste my time.
Old Jun 7, 2006 | 12:06 AM
  #35
NoMoreLS1's Avatar
Question
Originally Posted by Justin00SS
Hit yourself.
Yeah... ok. Yeah... bigger is always better with you guys. Might as well put a huge cam in the car. Better put a 5000 rpm stall in there while your at it. Put a 4.56 gear in the rear end too. It's an LS1 afterall.
Old Jun 7, 2006 | 12:11 AM
  #36
Justin00SS's Avatar
That has nothing to do with porting a TB to get better throttle response and a little more power.
Old Jun 7, 2006 | 04:37 AM
  #37
Bo White's Avatar
Can be anywere from a 3(just port/not caring on what it looks like) to a 6(put it on the mantel and show it off kinda job).
Old Jun 7, 2006 | 05:12 AM
  #38
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Or Jordan....
Old Jun 7, 2006 | 07:37 AM
  #39
TheBlurLS1's Avatar
This wasn't a waste of time, this was a learning experience for ya!
Parts modified incorrectly have unwanted consequences.
Old Jun 7, 2006 | 08:06 AM
  #40
ICRAZY6's Avatar
I purchased a ported and polished TB made my SLP. Its great. It opens the complete 90 degrees. and is ported on both sides of the blade. Any shop that does ports head can port the TB. Or just upgrade to an aftermarket and sell your stocker on Ebay. Better throttle response! Especially with the blade opening the complete 90 degrees. The stock one opens up about 75-80 degrees and creates some turbulence.
