Porting TB in ILLINOIS
Old Jun 7, 2006 | 09:53 AM
  #41
TORCHD 02 TA's Avatar
Hey TheBlur.. wnat to to come to chi-town and port mine
i am really thinking of doing this mod..
question will this cause any problems in the long run, or if i do other mods later down the road? well i need to get a tune with a ported TB?
Old Jun 7, 2006 | 11:15 AM
  #42
TheBlurLS1's Avatar
That's what she said...
I'd do a hackjob the likes of which mankind has never seen.
You will have no problems with it as long as you don't grind away where the closed TB blade makes it's perimeter seal. It is a great mod and ported throttle bodies sell like hot-cakes if you want to upgrade later down the road. You should not need a tune either. Be careful when disassembling it, as the throttle position sensor (oposite of the cable cam) has a small metal ring that people always ask which way it goes in.
Use a little blue loctite on the threads when re-installing the TB blade too, don't want those badboys coming loose!
Old Jun 7, 2006 | 12:19 PM
  #43
NoMoreLS1's Avatar
Wink
Mankind?
