o2 extentions!
Old Jun 5, 2006 | 08:40 PM
Hell'sChariot's Avatar
Default o2 extentions!
which ones do I need? Im getting pacesetter longtubes and there are two different extention ends. Flat or sqaure. Its a 2000 camaro ss. It being obd2 I think I read that I need the sqaure but I just want to double check.
thanks.
Old Jun 5, 2006 | 08:54 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
it is square....Make sure you don't get the LS2 ones. and you need 24" extensions too.
Old Jun 7, 2006 | 09:14 PM
dalejr8ls1's Avatar
QTP makes a good setup..i love mine
Old Jun 7, 2006 | 09:49 PM
RrCoX22's Avatar
is there a way to know which ends to get - flat or square, w/o having to unplug them
Old Jun 7, 2006 | 10:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is cake to get to them. They are most likely next to the transmission. They are the square ones 99% of the time on F-bodys.
Old Jun 8, 2006 | 01:19 AM
transAm-98's Avatar
you should consider just forgetting about the extensions and just buying some rear O2's from a vette. they are plenty long to use by themselves without any extensions. In my case and a few others the stock O2's won't run hot enough and will throw a code and cause your car to run shitty. The vette O2's are made to run hotter and they solved all of my problems. If you run a search you can see other peoples experiences with this.
Just something to consider. I ended up going through 2 sets of O2 sensors before figuring this out $$$$$$
