Ported TB Swap
Old Jun 6, 2006 | 03:46 PM
slim_john's Avatar
Default Ported TB Swap
Here is a follow up question about swaping my throttle body, since the one I bought as a smaller cam and I was told that I had to switch out the cam shaft of my TB and install it on the ported tb.
See this thread:
https://ls1tech.com/forums/showthrea...20#post4934420
I was wondering if instead of switch out cam shaft, if I could just switch out the throttle cable instead? Does that make sense or should I just switch out the can shaft?
Old Jun 6, 2006 | 03:51 PM
BIG_MIKE2005's Avatar
I was told by several on here the same thing. But I just installed mine without doin that. And it works fine so far. I also did the TB bypass with a little piece of metal tubing. It took about 20 minutes to put in the new TB & do the bypass. The TB I put on is a 2002 Port & Polished TB.
Old Jun 6, 2006 | 03:56 PM
slim_john's Avatar
Hey BIG_MIKE2005 I think I got it backwards: my stock TB has the smaller cam, the Ported TB has the larger one, do you remember what your situation was?
Old Jun 6, 2006 | 05:44 PM
motoxlifer's Avatar
That shaft/cam is very simple to R&R if you actually have to. Remove the TPS, remove the throttle blade, and then hit the shaft lightly with a hammer. Ther is a little washer that will fall off, i don't think you even need to replace it. Install new shaft and blade making sure it's not sticking, replce the TPS and your done. Oh yeah put the return spring back on too.
