valve cover options
Old Mar 26, 2003 | 08:23 PM
sleepersilverado's Avatar
Default valve cover options
i reciently installed some jessel shaft mounted rockers on my truck. i had to modify the valve covers . i would like to know if i could get some aftermarket valve covers with more clearance. like a sheet metal cover but i would realy like something that all my pcv stuff hooks up to basicaly a direct replacement. o and they are canter bolt.
thanks
Old Mar 27, 2003 | 03:17 PM
whatever's Avatar
Default Re: valve cover options
Thunder sells a valve cover spacer that will probably do the trick. Give them a call. I'm not sure if they(the spacer)are on the web page.
Matthew
<small>[ March 27, 2003, 05:06 PM: Message edited by: whatever ]</small>
Old Mar 28, 2003 | 12:54 AM
ttt
