Harmonic Balancers
Old Jun 19, 2006 | 07:54 PM
SCCAGT's Avatar
Question Harmonic Balancers
Can any SBC harmonic balancer be used for an LS1?I want to install an underdrive high RPM type on my hybrid.
Thanks!!
Old Jun 20, 2006 | 08:30 AM
TheBlurLS1's Avatar
That's what she said...
I would say no. We have 25% underdriven pullies for these cars that you can buy off the shelf from any sponsor. ----->
Old Jun 20, 2006 | 11:12 AM
jimdavis@professional's Avatar
LS1TECH Sponsor
LS1's and LS2's have a unique harmonic damper totally different from earlier small block Chevys. Also the LS1/LS6 Corvette uses a different damper than Camaros or Firebirds.
Old Jun 20, 2006 | 08:05 PM
SCCAGT's Avatar
Thanks, I'll check out some of the sponsors. My particular engine is a 99 Pontiac.
Old Jun 21, 2006 | 03:57 PM
87ssMonte's Avatar
The better question is , how are you guys reinstalling the Harmonic Balancer, assuming you don't have the GM tools.
Old Jun 22, 2006 | 08:32 AM
TheBlurLS1's Avatar
Put in oven (optional), slide onto snout, screw in bolt slightly longer than stock (or threaded rod/washer/nut), tighten untill it's sucked on enough to get a good bite with the old bolt, tighten old bolt untill it hits 22 ft-lbs, remove old bolt and install new bolt, tighten per LS1howto.com specs (cam-swap guide).
