HELP, y-pipe is knocking
Old Apr 7, 2003 | 07:31 PM
Red 01SS's Avatar
Default HELP, y-pipe is knocking
Ok, today I just installed a SLP y-pipe on my 01 SS. After I was done I took it out to see how it sounded. While I was out, under acceleration the pipe is knocking under my car. What can I do to stop this. Or has antone had this problem. What about poly trans mounts and poly motor mounts?
Old Apr 7, 2003 | 08:18 PM
DARK AGE 53's Avatar
Default Re: HELP, y-pipe is knocking
You shouldn't have any banging going on, loosen the clamps and re-adjust the y-pipe. Another thing to look for is the postion of the clamps. It's kinda of hard for me to explain but if you have a clamp near the under body that can cause the banging, rotate the clamp and see what happens.
Al
Old Apr 7, 2003 | 08:25 PM
Red 01SS's Avatar
Thanks, I will try that.
Old Apr 7, 2003 | 08:27 PM
NickMapleT/A's Avatar
I have a friend with the SLP y-pipe, and he has the same problem. The hooker comes with strategiclly placed dents for clearance. I wonder why the SLP doesn't have them.
Old Apr 7, 2003 | 09:12 PM
01redws6ta's Avatar
I had the exact same problem with my SLP y-pipe. I installed a polyurethane trans. mount and it solved that problem. I also did a poly torque arm mount while I was there. Beware of increased cabin noise from exhaust. The weak sloppy trans. mount serves as a noise isolator which is gone with the very stiff poly mount.
Old Apr 7, 2003 | 09:24 PM
Red 01SS's Avatar
Thanks, I already have the poly trans mount, but it is not installed. Thanks for the heads up on the extra noise.
Old Apr 7, 2003 | 09:26 PM
Red 01SS's Avatar
Old Apr 8, 2003 | 06:54 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Might also be the Y-pipe banging on the tunnel brace. You can just pull that tunnel brace off, the factory piece is too weak to do anything for you anyway.
 Michael S. Palmer
Old Apr 8, 2003 | 09:05 AM
The tunnel brace isn't all that great but it's better then nothing, if it's hitting the tunnel brace use some washers and a little longer bolts to drop the brace some.
Old Apr 8, 2003 | 09:07 AM
TaTommyWS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DARK AGE 53:
<strong> The tunnel brace isn't all that great but it's better then nothing, if it's hitting the tunnel brace use some washers and a little longer bolts to drop the brace some. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto. Worked for me!
I also pounded the bump in brace with a sledge hammer to flatten it out...
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 8, 2003 | 09:27 AM
2002z28b's Avatar
Had the same problem with my 02 z28. All I did was grabbed 8 washers and spaced the tunnel brace down. This way you dont have to beat on anything to stop that crappy banging noise.
justin
Old Apr 8, 2003 | 11:58 AM
jimmyblue's Avatar
Moderator
I had to beat my convertible X-brace severely
to get it to shut up, and the pipe somewhat,
just strategic "dimples". The washers didn't
do enough because they only lower the back
mounting points and the bind is up front if
you have the convertible style brace. The
whole thing wants to be jacked and shimmed as
you go tightening it up, this includes the
I-pipe too, all the way back to the gas tank.
Then you get a nice tight setup with adequate
clearances.
Old Apr 8, 2003 | 06:58 PM
RPM WS6's Avatar
<strong> The tunnel brace isn't all that great but it's better then nothing, if it's hitting the tunnel brace use some washers and a little longer bolts to drop the brace some. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I disagree. I ran without one for about a year and didn't notice any difference. But, then again, I have SLP 3pt SFCs, so I still had plenty of floor board support...
I know of many people that take it off and forget about it. Washers are a fine solution, but until you get the washers, if it's driving you nuts just take it off. You can always put it back on whenever you have the chance to buy some washers. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
