Kooks Primary Measurement
Old Jun 23, 2006 | 04:32 PM
NoMoreFWD's Avatar
Default Kooks Primary Measurement
I bought some Kooks 1 7/8" headers. When I measured the primary tube diameter, it checked 1 7/8" on the outside dia. I would think it should be 1 7/8" inside dia. Does anyone know how Kooks or other companies measure primary size?
Old Jun 23, 2006 | 06:39 PM
TheBlurLS1's Avatar
That's what she said...
Tubing is measured in OD, hose is measured in ID.
Old Jun 23, 2006 | 08:26 PM
Black Z/28's Avatar
Hmm, interesting. You learn something new everyday.
Old Jun 24, 2006 | 12:18 AM
Weezzer's Avatar
Tubing is measured in OD...
Sir,
You are only partially correct – tubing is measured in O.D. only up to 12”; from that point on it is measured in I.D.
Old Jun 24, 2006 | 01:00 AM
NoMoreFWD's Avatar
Thanks for the info. I thought headers would have used i.d.
Old Jun 24, 2006 | 01:32 PM
TheBlurLS1's Avatar
Originally Posted by Weezzer
Sir,
We call that PIPE not tubing lol. For smaller stuff its usually OD, but not always. 2" pipe we use in the plant is 2.375" or 2-3/8".
How bout this one, A/C men use OD for copper tubing/pipe, while plumbers use ID for the same stuff.
Old Jun 29, 2006 | 04:41 PM
Weezzer's Avatar
[QUOTE=TheBlurLS1]We call that PIPE not tubing QUOTE]
You obviously haven't worked with large diameter tubing.
I do know the difference between pipe and tubing.
Like I said before, tubing is classified by I.D. above 12".
Old Jun 29, 2006 | 11:06 PM
TheBlurLS1's Avatar
I was joking around, no need to be a douche about it chief.
