Problems with FAST 90/90
Old Jun 24, 2006 | 12:45 PM
z28misfit's Avatar
Default Problems with FAST 90/90
I just installed the FAST 90mm setup on my 99 z28. Everything works except the air hose that connects the mass air sensor to the throttle body. Stock throttle body size is 75mm so I made a relief cut in the hose. When I slid it over the tb it ripped back even further, so for now i just put duct tape over the small air hole near the TB. Any suggestions on where and what i can use to fit the 90mm throttle body?
Old Jun 24, 2006 | 12:50 PM
ty_ty13's Avatar
7 Second Club
go to home depot and get some fernco hose.... 4'' to 3.5 hump hose
Old Jun 24, 2006 | 02:41 PM
waterbug1999's Avatar
Well, I ran into the same problem. But, I had recently put a cold air intake on my 04 Z71. So, I cut the old bellows off and it fit perfect onto the the 90/90 set up. Just FYI incase you have something similar laying around.
Although, I did have the fernco mod, and it worked good as well, once you get it on.
Old Jun 24, 2006 | 03:46 PM
TheBlurLS1's Avatar
That's what she said...
You can fit the stock bellow (hose from MAF to TB) w/out cutting it. Intakehoses.com and hightempsilicone.com are some good places, as is Lowe's/Home Depot's plumbing section (fernco).
Old Jun 24, 2006 | 04:09 PM
CHIWS6's Avatar
that right the stock 1 will fit in there because i finish mt 90/90 setup today and all i did was lube the inside of the bellow with some oil and it will slide right in there!
Old Jun 24, 2006 | 05:15 PM
Photochop's Avatar
Or put it in some boiling water to soften the rubber so you can expand it. Using oil or lube of some kind could get in the mass air and cause problems.
Old Jun 24, 2006 | 05:17 PM
CHIWS6's Avatar
how can it cause problems if its after the maf???? your going to just lube i a little bit, im not telling u to put o quart of oil on there
Old Jun 24, 2006 | 05:18 PM
Just soak it in a quart of oil.. lol
Just dont use the microwave modd, that will melt a hole in it.. I know, I did that!
