fast 90/90 with 224 cam...
Old Jun 26, 2006 | 09:53 AM
99ccz28's Avatar
Default fast 90/90 with 224 cam...
i was wondering if getting the fast 90/90 setup would be worth it on a cam only car with all the bolt ons and a 224 cam or should i just stick with the ls6/ported tb? and also my i pipe on my exhaust is 2 3/4, would i pick anything going to a 3 in pipe? thank you
Old Jun 26, 2006 | 10:09 AM
GuitsBoy's Avatar
I would just stick with the ls6 intake. While you will see some gains, i dont feel it will be enough to justify the price.
Old Jun 26, 2006 | 11:09 AM
iamsickofitall's Avatar
until you decide to go with heads and/or bigger cubes, the LS6 intake and a ported tb are the way to go
Old Jun 26, 2006 | 11:19 AM
99ccz28's Avatar
thanks guys
Old Aug 1, 2006 | 05:32 PM
93camaro_zzz's Avatar
So if you had a H/C car, would it be worth it to go to the fast 90/90. How much do you think I would gain? I have the LS6/ported TB right now as well. Thanks guys,
Old Aug 2, 2006 | 03:59 PM
Noone knows?
Old Aug 2, 2006 | 04:01 PM
davered00ss's Avatar
Moderator
With a bigger cam and a good set of heads the 90/90 set up can be worth 20rwhp or more. It would kill the low end on a small cam like the 224. Plus you would probably not gain anything over an ls6 or fast 78.
Old Aug 2, 2006 | 04:03 PM
Rescue Ranger's Avatar
what about on a set of ported 62cc 243's and a 224/228? Any good then?
Old Aug 2, 2006 | 04:05 PM
Moderator
A friend of mine saw good gains from the 90/90 with a 228 ( Tony mamo cam I think)cam and a set of AFR heads (milled).
Old Aug 2, 2006 | 07:04 PM
So a better intake and freerer flowing TB will kill my low end? Doesnt make any sense. So the consensis(sp?) is taht this would be a good idea for my car? (H/C 231/237 cam) Thanks guys,
Old Aug 2, 2006 | 08:17 PM
I guess so.. I'll call up East Side Performance tomorrow (local shop and one of our sponsors) and ask their opinion on the combo
Old Aug 2, 2006 | 09:08 PM
01350ss's Avatar
it would hurt the low end because the intake of this size is geared to outflow everything in the mid and upper rpm's
Old Aug 3, 2006 | 12:00 AM
TheBlurLS1's Avatar
That's what she said...
I would stick with LS6/TB unless I was looking to make huge top end power or 430+rwhp H/C. Strokers are what really make these things shine.
Old Sep 18, 2006 | 09:30 PM
Jimmyz's Avatar
Question Port or not to port the intake?
I have a stroker and was wondering if its necessary to port the intake at all to get the best bang for the buck with this 90/90 setup. Got the 90/90intake and TB in the garage now. Been told the "out of the box" intake anit worth much at all....true?
Is porting worth it? I want MORE low end torque.
Old Sep 19, 2006 | 07:39 AM
GuitsBoy's Avatar
Porting tends to open up the runners and slightly raise the powerband (less low end) however on a big cube motor you could probably use the extra air. Im sure the cubes will overshadow any loss of torque from the intake.
