ASP install-can't be right?(PICS)
Thanks for the reply, So I wont leak oil from the front seal even thought the balancer isn't up to the seal, or those two have nothing to do with each other?
[/quote]
Did you lubricate the ballancer seal with oil? Hope that you replaced the seal with a new one too.
The seal occurs where the seal contacts the balancer collar. See the old balancer and the mystery will be gone.
Lastly, is Lock-tite a requirement for the crank bolt? I was told that with a torque spec as high as 240 ft/lbs, it shouldn't be required.
, was mobil 1 10w/30, and some lucus oil additive, also used lucus for my cam install. The Best V8 Stories One Small Block at Time
