catalytic converter
thanks
Actually, every sig you see with ORY in it means that person doesn't have cats, there are tons of us that don't have cats. I, uhhh, think we're all track only cars though. . .
. In my opinion this is a great mod for someone who wants the benefits of sound and mild power without spending the 500-600 for aftermarket headers and an offroad y pipe or for someone with clogged cats. Let me know if you have any questions about the mod because I can definetly help ya'll out...Josh. The Best V8 Stories One Small Block at Time
thanks
Yes it will make your car louder, but worse sounding as well. If you want louder simply run a different catback or dual exhaust that has less mufflling.
A SLP Loud Mouth or GMMG or TSP Rumbler X duals.
As for bhp - yes stock CATS are restrictive, but the exhaust is a whole system you need to do the whole thing to get any real gains. So simply removing the stock cats won't suddenly turn your car into a fire breathing street warrior.
Also it is a federal offense to remove CATS. However many states don't actually check.
CA is different though and you will need to pass a visual test as a rule, meaning they will look under the car. ODBII test is where they plug a scan tool into your cars PCM. Without CATS it will throw a code.
Fake cats and deleting of codes via tuning can work to pass such things. But again in CA it is unlikely to work.
Also if you have to pass a sniffer test there is no way to do it without CATS.
Essentially if you are in CA forget about building a modded car the same as everyone else.
Get a aftermarket catback. And leave the rest of the exhuast alone, unless you find a way of really upping the HP.
Pulleys, intake manifold, TB, lid, heads, mild cam are the way to go. Non CA guys can have wild cam and LT headers and make a decent chunk more HP.
Large displacement motor or a supercharger is really you only option for BIG power.
You then will need shortie headers (CARB approved for 100% legal) and high floe CATS (probably metal matrix ones).
In short:
LEAVE THE CATS BE!
your right about that. its only a matter of time before every state is like that
thats why i'm gonna enjoy it while i can
