Best sounding bullet: VOTE
What would your opinion be on me running my Flowmaster muffler at the end of my SLP ORY? When I said I wanted to quiet it down I only meant the resonation/rasp sound. It can scream all day long, but there is almost a metallic rasp from 2-4k. I know that it will be loud being dumped under the car, becuase it is dumped under the car right now. I have the SLP LTs, ORY and the stock catback. However, there is a Flowtech exhaust cutout that I run open underneath the back passenger seat. I tried to close it up but the rasp was MUCH more noticeable because the deep sound had been quieted down.
I used to run a Y with a bullet dumped at the rear axle and the system i have now is much lighter and nicer sounding.
If it's the 80 series single in dual out then no. It won't actually fit under the car and it flows no where near good enough for a LS1.
Rasp can be an issue, a cam swap will probably eliminate some of it though.
If you want to try it out cheap I would get a Magnaflow muffler off Ebay. One of the Ebay shops sells them for like $60 each. And try it on the Y and dump under the car. If it still drones too much you could add another identical muffler and run two in series. It should really affect flow but should reduce db and rasp.
However it looks like you are intending more track than street orientated if you plan on a cage. This means you will be wanting a body mounted torque arm (check out UMI Performance).
A custom dual exhaust built around the FITTED torque arm would be the best route. 3" tubing into a muffler per bank and dumped before the axle. It will weigh more than a Y setup but the extra potential would IMO out weight (no pun intended) this fact.
If you plan on BIG power via nitrous or some other power adder I think a 3" Y pipe will be limiting. Which means you really need to step up to a 3.5" or 4" Y pipe after the merge. You would then be forced pretty much to go with a Borla XR-1 in 3.5" core (or bigger if they do it), this will be the best way of handling exhaust flow. Again you could in theory run two mufflers in series without too much detrimental affect. The only thing is the large core Borla's are expensive as will fabbing the tubing. So I'd still go duals. Just watch for the torque arm though!!!
This is where it's really tough, if you plan a strip car then you will break your rear end. Most of the torque arms have stilghtly different fittings for the different 12 bolt axles available. You'll need to have a look and see if one works with both axle types.
If you're going for a quick fix and anticipate going with true duals sometime in the future, just order a dynomax bullet and save yourself the $100 on the xr1. The xr1 sounds good, but with very little pipe in front of either of the mufflers, both are going to be pretty loud. Ive got a buddy of mine that just did this same thing and modeled it off of what I did (but didnt run a muffler in the stock location). He had a local shop weld up a flowmaster merge collector (dual 3" into a single 4" out) and had a 4" bullet welded up behind that with a turndown right after it. Let me tell you that it sounds freakin SICK even on an old LT1. Mine has the same setup but a 3.5" e-cutout behind the bullet so I can control the volume when I want. Mine sounds a little deeper and is more 'poppy' sounding due to the 110 lsa on the cam. I'm going to try and get some vid of the car in the next few days and hopefully it will do it justice.
P.S. fogot to mention its going to be true duals
heres my exhaust setup on an ls1 .. its one of the guys on here .. i forget
http://videos.streetfire.net/search/...11292ec30d.htm
