Best sounding bullet: VOTE
VOTE
I voted dynomax bullet. Had one for six months. Liked it. You might find that a dumped bullet with the t-rex and no carpet is too loud for daily driving though.
I know it will be loud and that does not bother me. Noise is the least of my worries with the TRex, 4400 stall and 4.10s. I just want to get the rasp/resonation under control.
I asked a mod to close the last thread. Keep the votes coming.
Still evil and wild when your WOT.
my cam size and ci are a lot larger than your's as well..
the amount of weight saving will not be worth it unless you plan to strip your car. That means no air con, remove electrical goodies (stereo, windows, seats), ditch the interior and consider running perspex windows instead of glass and carbon fibre body panels.
A totally stripped out setup the weight saving will be a minor contribution. On a relatively full weight car it will have ZERO affect. You'd be better off just going to the toilet before driving the car.
As for which muffler????????????????????????
Come on, every one has their own opinion which is best, you'll just get six of one and half a dozen of the other in terms of responses.
And then it will only be what people have or have been told by others, totally regardless of whether it is best or not.
As for quieting it down.
A single bullet really isn't going to do much in terms of db reduction, also by dumping under the car the car itself will act like an acoustic guitar, so resonance and drone are still very likely.
Plus about 90% of bullet mufflers are built the same. Serrated core with metal packing in a stainless steel body. And because of this 99% of bullets will all sound pretty much the same. With comparable flow rates.
The smaller the muffler diameter the less packing, which means less muffling and louder.
Chambered mufflers will sound different. Such as Flowmaster 10 Series, Powerstick or Stainless Works chambered mufflers. All flow great and sound great.
The Magnaflow bullet is pretty decent and from Ebay is also very cheap. Borla XR-1 is more expensive and really offers little over the Magnaflow for your setup. The Borla is available with a 3.5" core which would be worth while if you plan to run a 3.5" Y pipe.
In fact, where are you planning on putting the bullet muffler? I assume you already have a new Y pipe? Is it ORY or catted and is it 3" diameter?
BTW - A Sweet Thunder muffler isn't a bullet but a chambered one, these also "neack down" so odon't flow as well as some of the others. The Powersticks and Stainless Works Chambered mufflers are the same thing but should out flow the Sweet Thunder.
If it where me I'd seriously look at TSP's dual exhaust for your setup, unless you plan on runing a body mounted torque arm that is. If you do then a custom set of duals would be required. But if you plan on dumping before the axle it really wouldn't be a difficult or expensive setup to have made.
What would your opinion be on me running my Flowmaster muffler at the end of my SLP ORY? When I said I wanted to quiet it down I only meant the resonation/rasp sound. It can scream all day long, but there is almost a metallic rasp from 2-4k. I know that it will be loud being dumped under the car, becuase it is dumped under the car right now. I have the SLP LTs, ORY and the stock catback. However, there is a Flowtech exhaust cutout that I run open underneath the back passenger seat. I tried to close it up but the rasp was MUCH more noticeable because the deep sound had been quieted down.
