Whats next
If you have an M6 you could also consider a short shifter, clutch, save for a rear end.
If you have A4, consider matching a converter with your cam choice.
Btw, dyno tuned, efi tuned, same thing. I'd assume you will get your car dyno tuned with EFI Live. Save your money on a tune until you get cam. Just my 2 cents.
Good luck modding.
Good luck modding.
) ALL NEW PRC LS6 CNC Ported Heads = $999
TSP Camshaft, PRC Spring Kit & Pushrod Package = $689.99
( With the ms4 on a 110ls1) " Not sure if it will fit with the ls6 heads"
If youve got the money go with ETP or AFR
GM LS2 Timing Set = $90.99
TSP Ported LS6 Oil Pump = $129.99
Comp Cams Replacement Hydraulic Roller Lifters = $189.62
Ls1 speed 42.5# injectors = $299.99
Deluxe Heads & Camshaft Bolt & Gasket Kit = $279.99
F.A.S.T. LSX 90mm Intake & N.W. 90mm Combo = $1,249.99
Powerbond 25% Underdrive Crankshaft Pulley = $199.99
If your an auto
Vigilante Converter 3200-3400 Stall = $699.99
If an m6
Whatever shifter you like better and obviously a better clutch.
Poly Motor Mount Kit 1998-2002 LS1 = $49.99
BMR Boxed Subframe Connectors = $169.95
BMR Chrome Moly Shock Tower Brace = $129.95
BMR Lower Control Arm Relocation Brackets, Bolt On = $119.95
BMR Chrome moly tubular control arms w/poly bushings = $159.95
BMR Chrome Moly Adjustable Bolt-In Torque Arm = $469.95
BMR Driveshaft Safety Loop = $99.95
New shocks/springs
And there a whole bunch more but im not that bored to continue.
This would be a pretty sick combo.. If I only had money. All parts were found off of TSP + Ls1 speed.
