Y pipe
Old Jul 13, 2006 | 04:07 PM
orangefun's Avatar
Default Y pipe
I have looked every where to find the right answer. Anyway some poeple say put an aftermarket Y pipe and some say dont even wast the money unless you got headers, who is right, and remember I have an 01 not a 98 -2000, and if i threw on LT I would have to pull them off every 2 years because of smog (CA). Can someone help????
Old Jul 13, 2006 | 04:08 PM
zboner's Avatar
i would, they flow a lot better then the stock ones, just look at the stock one.
Old Jul 13, 2006 | 04:16 PM
Formy's Avatar
You and I are in the same boat. Longtubes are not "allowed" here in Cali. You can cetainly pass the sniffer as long as you have the cats and your EGR stuff and a tune. However you will fail the visual because you will have moved the stock location of the cats.
Some smog stations pay attention to this others do not. An aftermarket Y pipe with longtubes will give you more power but technically it is not allowed here in Cali.
Old Jul 13, 2006 | 04:44 PM
jpat1023's Avatar
Yes you need a new one, however, I wouldn't worry about it until you put headers on. Unless you have no plans to put headers on, then I would do it when you get a catback, because, as stated above, the stock y-pipe is not the optimal design when it comes to air flow...have you seen it?
