Gauges
Oil pressure is good if working right, water temp is a dummy gauge on 99-02s.
Volts and fuel are meh.
Just my thoughts on them.
would the water temp gauge at least let me know if its over heating???? and can i use the stock sender w/ a new guage???
The dummy guages (99-02) will tell you if it's overheating.
I haven't seen any temp guages that use the stock sensor myself. You're going to have to tie in a fitting with a new guage somewhere else should you choose to go that route. You can run a T in the existing spot, or put it on the back of the passenger side head (there's a plug). You can't remove the stock sending unit because it actually tells the comptuer the corret temperature, just not the driver.
