!panel under FIPK?
Old Jul 18, 2006 | 12:07 PM
SRpwred240's Avatar
Do you think there is any performance gain of taking the washer fluid res out? Do you think it would help get more coldier air to the FIPK?
Old Jul 18, 2006 | 12:18 PM
parbreak's Avatar
Performance Gain: On a dyno maybe with a large fan
Seat of the Pants Feel: Not that I could tell
Definitely allows more air flow to filter, your removing a large obstruction.
I removed mine mainly for appearance reason, same reason why I removed on the AC crap, relocated the coils, etc, etc, etc. Main objective was to clean all the crap off the engine so the LS1 could actually be seen.
Bryan
parbreak
Old Jul 18, 2006 | 12:47 PM
hot black trans-am's Avatar
The support also forces air through the radiator. By taking it off, your car will run hotter. I wouldn't want my radiator flopping around in the wind. You need to seal it to get any kind of an advantage over just doing the free mod. What kind of weed are you guys smokin?
Old Jul 19, 2006 | 10:45 PM
rich Z's Avatar
I removed the ac shroud once and the cars engine temps were lower and the iat's dropped 30+ degree's.
Old Jul 20, 2006 | 07:17 AM
Traitor's Avatar
OK guys...last night I started hacking up the stock support. I cut it all out, the thin vertical piece and the big horizontal piece. Sanded it down, it actually turned out OK.
On installuniveristy they left that thin vertical piece. Was it a mistake to cut that out? I used one of my garage mottos...when in doubt , just chop it off.
EDIT...actually I think 2 mottos apply here...chop first, ask questions later. lol
On a side note, I also installed a ported TB at the same time, car definitely felt a little stronger.
