!panel under FIPK?
So, I decided to just leave the whole panel out. I know, I was thinking those K&N guys are alot smarter than me...if they include it in their kit, there's a reason for it.
Well, the only reason I can see for it is to secure the filter (theres a nut/bolt on the tip of the filter that screws into the panel) and to attach the egr breather to.
So basically I have a big ol K&N just hangin out there. Is this going to be a problem? It's relatively secure, it's not rock solid, but you have to use a little force to budge it.
I have thought though that if this was such a great idea...why does no one else do it?
Thanks guys.
Chris
Should I put the panel back on, am I going to F anything up, or just leave it out?
Another option is to put the stock plastic radiator support on and cut it out for FRA if you've really got the itch. You're not going to see any gains from doing anything, plus you've got the SS scoop for plenty of flow action.
Taking the washer fluid reservoir out is'nt a bad idea. Never use it anyways.
I'll take another look at it once my ported TB comes in.
I can't even remember when I took it off (2 years ago?), and it has just recently become my weekend warrior.
I hate it when your driving behind someone when they use theres...sprays that **** all over your car.
Did you leave the little extension that you attach the front of the filter to or did you just cut the whole middle section out and let the filter hang and if so has that been a problem (come loose)?
Thanks
