Please Help.... Before I set the car on Fire
Things I have done to try and get rid of it are: New Plugs, Wires, fuel filter, seafoam through brake booster, seafoam in gas tank, cleaned maf, and checked the air filter.
So after work tonight I got the mechanics scanner and scanned it. Its a Snap-On Modis same one my High School has anyway the codes its setting off are P0137 and P0157 both are something about the 02's
Any Help will be much appreciated and needed
PS: Does anyone else have this problem or had this problem if so what have you tried.
DTC P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
Your rear O2's are probably unplugged or something, they have no effect on how the car runs though, so it's not your problem.
Maby it's just a natrual thing? lol What kinda hesitation are we talking about here?
But the cars down on power slightly and it will pull then stop for a split second then come on again.
actually now that I think of it its really around 3500 rpms (my bad)
P.S. This is my 2nd M6 LS1 I had one before the CHevelle and it didnt do it either, Hopefully I figure it out soon because doing this and that isnt good since I'm 17 and only make $6 bucks an hour part time and the fact that I pay for my own stuff including the car.
mines thrown a light as well but went away after 2 or 3 starts
I'll see if the mechanic will look at it for me
--Thanks
Get those codes cleared and see if they come back... that might give you a better idea as to what is going on, they could have been stored from who knows when.
Did you do new plugs after you seafoamed the car? If not, then I'd pull them and see what they look like. Was the fuel filter changed after the seafoam gas tank stuff what run thru?
I'm goin with Blur on the MAF thats next
BTW the things listed in the first post were to try and get rid of the stumble it had this before all of that
THe main thing that gets on my nerves is I want a Ram Air hood for it but need to get this fixed before I can save for the hood.
