Motor mount torque spec question...
Old Jul 17, 2006 | 08:43 AM
ilirw325's Avatar
Question Motor mount torque spec question...
I searched and looked in an old manual and I think I only found half of what I was looking for....
motor mount clamshell to block bolt torque specs......37 ft lbs
Is that correct?
What is the torque spec on the long bolt that connects clamshell/motor to pedestal/car?
Thanks
Old Jul 17, 2006 | 09:02 AM
Luna's Avatar
https://ls1tech.com/forums/showpost....9&postcount=49
JRP pwns you.
Old Jul 17, 2006 | 09:06 AM
ilirw325's Avatar
thanks....looks like 37 was correct
and looks like 70 ft lbs on the big one
What is the "engine mount through bolt nut" that says torque to only 89 IN lbs?
Old Jul 17, 2006 | 09:24 AM
ilirw325's Avatar
also....were you able to actuallly get a torque wrench on each of the four mount to motor bolts?
I didnt see any loc-tite on the threads, is it nessc. on any of the bolts?
Last questions
Thanks
Old Jul 17, 2006 | 09:36 AM
TheBlurLS1's Avatar
That's what she said...
You don't want to tighten the big bolt too much because you will just bend the mount together. It will also not be able to pivot as much.
Don't worry about loctite on them, and I just, to steal someone else's phrase, "German torq'd 'em"....... "Guten-tite".
Old Jul 17, 2006 | 01:08 PM
ilirw325's Avatar
haha thanks "Guten-tite" sounds good to me
Old Jul 17, 2006 | 04:08 PM
ilirw325's Avatar
Ive been reading old posts, and have a new question.....
What is the correct way to torque the long through bolt and nut so it isnt over torqued? anyone have any suggestions or should I just torque it like any other bolt?
Thanks
