Still Too Hot
Old Jul 18, 2006 | 05:15 AM
Jpr5690's Avatar
Default Still Too Hot
Ok My 2002 T\a Still Likes To Get Up Into The 210 Range During The Hot Part Of The Day .. As Of Now I Have A Ewp & No Thermostat.... The Car Is A Head And Cam Car .. Te Electric Fans Are Working Good I Dont Understand Why Its So Dam Hot!!!
Also What Can I Do To Bring The Temps Down?
Old Jul 18, 2006 | 08:12 AM
2 SSlow's Avatar
when my temp gage worked, i was running right around 200-210 all the time. I havent had a temp gage since i put the cam in 9000 miles ago, i broke it
Old Jul 18, 2006 | 08:25 AM
youngrigo's Avatar
i also have a 2002 camaro ss and before it would run at about 200-210 now ive noticed that lately its been running between 210-220 im running no thermostat and fan setting at 180 could this be just because it has been over 100+ were im at?
Old Jul 18, 2006 | 08:43 AM
TheBlurLS1's Avatar
That's what she said...
Have you tried flushing out the system? Does your overflow dipstick have brown **** on it? Have you cleaned the actual outside fins out on the radiator? Mine had a sock in it when I boght the car.
Use the method outlined in this thread to flush your system. Theres more on page 2.
https://ls1tech.com/forums/generation-iii-external-engine/476478-dex-cool-coolant.html
You need to fix it. That temperature sending unit (thing on the head that I suposse you broke) does a helluva-lot more than just tell YOU what the temperature is. If you've ever looked at a copy of HP tuners, you'd realize that just about every damn table in the PCM has the parameters setup adjusting for the temperature of the car at any given time.
You have a dummy guage, it's going to read that temp no matter what. If the car was running 185, it would still read the same on the guage.
Old Jul 18, 2006 | 09:01 AM
zboner's Avatar
yup on 99-02 cars they had the dummy gauges, the 98's worked
Old Jul 18, 2006 | 09:36 AM
TUCKZ28SS's Avatar
My car is a head and cam car too. Yesterday it was 97 degrees in NY, my car was running for about an hour. It got up to 210 degrees, my mechanic told me that that was where you want the temp to be. He also sugested removing the plastic shroud in front of the radiator and hollowing out the nostrils to get more air.
Old Jul 25, 2006 | 11:12 AM
Jpr5690's Avatar
Removing The Shroud Is A Bad Idea And Hollowing Out The Nostrils Wont Help Cooling ..jmo
Old Jul 25, 2006 | 11:20 AM
YellowMonster87's Avatar
I disagree, I have a 02 ws6, my friend has an 01 ws6, and his brother has an 01 ws6. I was the first to get the rain guards out of the nostrils as well as taking the honey combs out and replacing them with the brian green nose pieces....I DO NOT HAVE THE BRIAN GREENE KIT, JUST THE CORNER PIECES, however i have noticed a huge difference with throttle response as well as having our cars scanned and my air temp entering the car is on average over 10 deg. lower and my engine temp is substantially lower then both my friends and his brothers ws6. I strongly reccommend deleting the rain guards they serve no purpose. I have been in countless turential down pours and never had a problem highway driving or in town
but hey its jus my .02 so take it for what its worth
Old Jul 25, 2006 | 11:29 AM
allngn_c5's Avatar
Get a 160* Tstat and everything should be cool. No pun intended. My fans come on at 180, and the second one at 190. I never get hot, so far, knock on wood.
Old Jul 25, 2006 | 03:38 PM
Jpr5690's Avatar
AND I COMPLETLY AGREE WITH YOU ON THE PONT THat modding the intake path will lower iat temps but it will do virtually nothing to the temp of the coolant as the intake is not what so ever involved with the cooling system.. this was my point.. its kinda like saying lower your tire pressure or replace your brakes yea it may be a good idea depending on your situation but it has nothing to fo with engine temps
furthermore by cutting the radiator shroud you are actually redirecting air away from the radiator this will undoubtly increase coolant temps..
Old Jul 25, 2006 | 03:42 PM
Jpr5690's Avatar
also guys there is a fairly simple way to make the stock gauge read fairly accurate i modded mine and not it is pretty close what it shuold be
Old Jul 25, 2006 | 03:51 PM
texinteg's Avatar
and what is this simple way to make the gauge more accurate?
Old Jul 25, 2006 | 04:01 PM
Jpr5690's Avatar
ah, ha ! intrest !!!!
if your intrested send me an e-mail to jpr5690@aol.com i will send you the cluster diagram along with an instructions set...
i dont wanna hijack this guys thread as he does need help being his car is melting but keep in mind this does require removing and modifying the gauge cluster (easy imo)
Old Jul 25, 2006 | 04:52 PM
lt1formula2000's Avatar
you have mail
Old Jul 25, 2006 | 05:17 PM
Jpr5690's Avatar
back at ya
also if you search back about 6 months in the electrical forum i did a complete writeup on this
Old Aug 14, 2010 | 12:57 PM
bfrancis757's Avatar
Default 98 Camaro SS, LS1, fans stopped working
anyone know what all could make the fans stop working? All fuses are good, relays are new...
Also, does anyone know how to bypass the 02 sensors?
Old Aug 14, 2010 | 01:49 PM
Flawless02SS's Avatar
Just buy a Auto Meter water temp gauge and be done with it. 99-02 gauges all read 210. Or just drive it, if it get hot for real, it will let you know.
Old Aug 15, 2010 | 01:19 PM
libertyforall1776's Avatar
First I heard this -- what changed in the 99-02 cars?
Old Aug 15, 2010 | 01:21 PM
The hot engine is better for more efficient combustion -- this is the reason they run hot, folks.
Old Aug 15, 2010 | 01:22 PM
Motors failed?
O2 emulator or tune them out on the PCM...
