Installing a Loudmouth after a stock
first you will want to jack the rear passanger side up, remove the rim and tire,remove the panhard bar, and the upper panhard bar, unbolt the swaybar endlink. unbolt the lower part of the shock. let it dangle, the rear end should drop down. and be near close to the ground. unhook the left side of the catback from the rubber hanger and then the right side hanger should unbolt. remove the connection at the i pipe and y-pipe. then pull the whole catback to the back it should drop down then twist it out from underneath the car it will come out if slid to the right and lifted the right way.
