pacesetter exhaust leak
I can't tell if it's from the header gaskets (percys from speedinc) or where the pacesetter's collector is held to the y by an impact tightened band clamp.
Here are my two questions:
Could I have developed a gasket leak with less than 1,000 miles on it already?
and
Is it reasonable to weld the headers to the y pipe?
I'm pretty sure this will be my last setup unless I decide to run duals later on down the road, but if it must be welded, it will be. Doesn't matter how loud I turn up the music, I can still hear the leak. Oh and it doesn't help I'm a perfectionist.
Thanks
I have the same faint ticking at idle and low rpm after I installed my pacesetters. It seems to be getting louder. I had a couple people listen to it and they said they could'nt hear it.
Maybe the thinner walls of the headers have just made the valvetrain noise louder? Maybe I'm just paranoid? I've never had an LS1 with LTs so I'm not sure what sounds right and what does'nt.
