Where Does The Bump Stop Install?!?
Old Aug 7, 2006 | 05:47 PM
Xtreme57's Avatar
Default Where Does The Bump Stop Install?!?
Hey, just got my Mufflex bump stop, but i can't tell where the heat shield is from the little graphic included with the instructions.
I have a custom y from them, so I don't know if i still have a heat shield ...
Anyone have a pic of where this thing goes?
Thanks.
Old Aug 7, 2006 | 07:14 PM
Xtreme57's Avatar
Drivers side or passenger side???!!
ANyone?
Old Aug 7, 2006 | 07:23 PM
V6 Bird's Avatar
ANyone?
Goes under the seat.
Old Aug 7, 2006 | 07:37 PM
Xtreme57's Avatar
WHICH ONE??
Old Aug 7, 2006 | 08:40 PM
Xtreme57's Avatar
I know someone has installed this thing.
Old Aug 7, 2006 | 08:45 PM
Caribe's Avatar
It goes near the underside of the driver's seat.
Old Aug 7, 2006 | 08:47 PM
Xtreme57's Avatar
on the inside or outside though? I tried searching for pics, but it's almost impossible to tell which side it goes on under the car from the angle of any of the pics i found...
Old Aug 7, 2006 | 11:06 PM
TheBlurLS1's Avatar
That's what she said...
It doesn't matter which side of the pipe it's on, as long as it's the driver side. I would pull the pipe down as I was installing it to kinda preload the rubber part and get it as tight as possible.
Are you getting banging?
Old Aug 8, 2006 | 01:32 AM
Xtreme57's Avatar
Oh yeah it bangs under heavy load (ie geting on it in 1st gear).
I managed to get it on there before, but my Y is set up differently. My drivers side cat doesn't go parallel to the door, it goes perpendicular (mounted facing the doors basically), so i don't know if the bumpstop should go in the 'stock' location?
Old Aug 12, 2006 | 01:26 AM
ShevrolayZ28's Avatar
https://ls1tech.com/forums/showthrea...hlight=mufflex
Old Aug 15, 2006 | 12:14 AM
Xtreme57's Avatar
Originally Posted by ShevrolayZ28
yeah i found those pics before and eventually figured out how it went on. However, i loaded it pretty well, and although it doesn't "bang", there's still a heavy vibration ... is there any other way to improve the situation?
I don't think I can load it anymore than it is but it's still noisy under heavy engine load ...
Old Aug 16, 2006 | 12:27 AM
Xtreme57's Avatar
anyone on this?
Old Aug 16, 2006 | 01:36 AM
Caribe's Avatar
Cut some pieces of a rubber hose(radiator hose) and place in between y-pipe and the car. That might help.
