pulley questions
Old Aug 9, 2006 | 01:31 AM
SoCalZ28's Avatar
Default pulley questions
im about to put a 25% underdrive pulley on my 99 LS1. does anyone know the size of belts im gunna need before i take this all apart? also, woiuld the pulley puller you can rent from autozone work smoothly? lastly, will i need to switch to a 160 thermo? all tips and tricks are really appreciated!!
Old Aug 9, 2006 | 02:22 AM
Starz T/A 17's Avatar
the pulley puller you can rent at autozone/advanced will work fine just make sure you get the right one, Their really isnt a need to switch to a 160 thermo b/c all you are doing with a pulley is making it easier for the engine to run
Old Aug 9, 2006 | 07:38 AM
bigti99a's Avatar
best thing i can say is go slow. deniately get a new crank bolt and the threaded rod to instal it, i used a longer bolt and saw that the rob would defintaely be the better tool to use. i had great luck heating the new dampener when i went to put it on. slid on like budda. i got my belts from texas speed. pretty happy with results, you should be able to feel it a little. yeah i also dont see you needed a lower stat. besides are cars runn best at about 190-200. and if you didnt get the fans reprogramed it wouldnt do any good.
Old Aug 9, 2006 | 12:42 PM
SoCalZ28's Avatar
sounds funny but... what size of rod do i need for this install
Old Aug 9, 2006 | 12:48 PM
SoCalZ28's Avatar
and which puller from autozone is the right one??
Old Aug 9, 2006 | 08:55 PM
bigti99a's Avatar
crank bolt specs are 16mmx2.0 thread. and you will need it to be like 150mm or so. as far as puller i used my buddys. the 3 jaw at autozone should work.
Old Aug 9, 2006 | 08:57 PM
bad6as's Avatar
do u need a new shorter belt for the ac to or?
Old Aug 9, 2006 | 09:01 PM
Mssingkid's Avatar
I believe so.. Just got my pulley in today, (PITA To find At the moment BTW!) and had two belts in the box..
Old Aug 9, 2006 | 09:02 PM
bad6as's Avatar
where from?
Old Aug 9, 2006 | 09:17 PM
Mssingkid's Avatar
where from?
Thunder Racing... I'm sure they have some more belts in stock, if not they can give u the size you'd need...
Old Aug 9, 2006 | 11:58 PM
SoCalZ28's Avatar
well, i got some part numbers for the size belts that will work with a 25% under drive and im doing the install tomorrow night. should 15 min at 200 degrees be right for warming the UD pulley for it to slide in like butter? knock on wood...
Old Aug 11, 2006 | 12:18 PM
SoCalZ28's Avatar
well, i talked to SLP about heating up the UD puller so i can slide it in, they brought up a good point. there is rubber in there and heat from the stove would mess with the balance of it. all in all, i rented the puller form autozone, got the car in the air and took a look at what i was getting into... i dont feel confident doing this mod, it looks like i will need to pull the radiator and disconnect some other stuff for clearance. im going to hold off on this mod for alittle
Old Aug 11, 2006 | 01:53 PM
bigti99a's Avatar
i didnt disconect anything. but the puller your renting could be longer. i agree with the rubber in the ballancer, i took a propane torch to the inside of it to try and concetrate the heat only where i needed it. just rotated the pulley and kept the torch lightly on it heating it real slow. you can do it without heating it its just easier when the dampener has some heat on it.
