Cleaning MAF screen
Old Aug 9, 2006 | 02:46 PM
irnbru83's Avatar
Default Cleaning MAF screen
I put in a K&N air filter recently and when i was going about cleaning the air box, i saw a bunch of crap stuck to the MAF screen. I read somewhere that you are not supposed to put any pressure on that, so how do you clean it? Or am I being paranoid and i should just scrape the crap off. Looks like a few little pieces of paper are stuck to it, but that blocks a seemingly significant portion of the screen.
And yes, I'm new at this.
Old Aug 9, 2006 | 03:27 PM
jimmyblue's Avatar
Moderator
You want to figure out why your air filter is
being so ineffective. But I'd go get a can of
"QD" cleaner from Home Depot and just spray
until it runs off clear (paper towel will show).
If this is the stock Oreo style MAF, you can
disassemble it to clean the front piece. But
the center section wants the wires clean too.
You need a Torx screwdriver, though a flat
of exactly right size will do if you're lucky.
Old Aug 9, 2006 | 03:51 PM
YouCantCmyZ28's Avatar
also wondering this same thing.......im going to try and clean mine once my TB comes in because i think its causing some problems with my car. i went to radioshack and bought some electronics cleaner and was going to try that but what is the "QD" you are talking about. i def dont want to use carb cleaner or anything cuz i know it will fry it. any other suggestions?
Old Aug 9, 2006 | 04:04 PM
irnbru83's Avatar
I haven't owned the car it's whole life, so I'm guessing previous owner did something screwy (couldn't possibly be my fault )
But seriously, the old air filter I pulled out of there was trashed. This car is turning out to be a good lesson for stuff I should've checked when I got it a year ago. The airbox was full of dirt and the filter was clogged. After cleaning and a good filter, my baby is flying. who knows what else i need to look at. Going to change the oil filter today and i hope it's not a scary mess in there also. (haven't done many miles on it, so i didn't think to change oil filter yet)
Old Aug 9, 2006 | 04:13 PM
irnbru83's Avatar
QD = quick detail ?
Old Aug 9, 2006 | 05:39 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
can it be sprayed while still on car....obviously mine is just a little dirty, not stuff all over it.
Old Aug 9, 2006 | 06:58 PM
1BadBlueSS's Avatar
The company CRC just came out with a cleaning spray just for MAF sensors. I know that all napa's carry it or can get it (since i work for one), but im sure any auto parts store that sells CRC brand products could get it.
Old Aug 9, 2006 | 07:55 PM
irnbru83's Avatar
i'm guessing you have to remove the MAF in order to clean it...?
Old Aug 9, 2006 | 09:51 PM
BayAreaSS's Avatar
Yes, the MAF needs to be removed
Old Aug 10, 2006 | 07:15 AM
Marblehead's Avatar
Take a look here. Might be the same reason why my MAF was full of junk.
https://ls1tech.com/forums/generation-iii-external-engine/556748-air-lid-causing-p0171-p0174-codes.html
Old Aug 10, 2006 | 12:50 PM
TheBlurLS1's Avatar
That's what she said...
Only oil the bottom of the K&N filter, let the airflow through it pull the oil in. This should help next time.
Old Aug 21, 2006 | 07:00 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Hey,. just so that you know,... if you use the CRC M.A.F. cleaner......... Seriously let the stuff dry for an hour or more if need be (even though it says that it evaporates in minutes). If you don't,.....lol....... enjoy try'n to start her up! Trust me on this!!
