Number one primary barely touching K-member.
Old Aug 17, 2006 | 12:29 PM
Build #1's Avatar
Default Number one primary barely touching K-member.
The number one primary on the passenger side is barely touching the K-member.
I tried to tweek it off of it but it just goes right back. I can move it off of it with a small screw driver.
Should I leave it be? It will probably cause knock retard. How has everyone that this has happened too gone about fixing theirs? I never hear it either.
Old Aug 17, 2006 | 01:06 PM
DustinSS's Avatar
My pacesetters luckily fit fine on my car....buthave heard of others with the same problem....just heard of them notching out enough of the k member to avoid it hitting.
Old Aug 17, 2006 | 01:54 PM
Turo's Avatar
My Jet-hot headers just barely touched the k-member also. As soon as I started the car the motor vibrations caused the headers to hit the k--member. I just took a dremel tool and clearanced the k-member slightly in order to clear the headers.
Old Aug 17, 2006 | 02:12 PM
LS1vazquez's Avatar
Same thing here, I have Jet Hots and the driver side header is physically contacting the K-Member. It does knock on start up but for what it's worth, the header seems to be notching itself into the K-member and I haven't had issues with knock retard.
Old Aug 17, 2006 | 02:37 PM
sdbrown84's Avatar
A good mechanic may be able to heat up and bend the header (had this done to my QTPs) or you could notch the K-member. Most expensive route would be to get the aftermarket K, which is about $500.
Old Aug 17, 2006 | 05:00 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
you are right---a Performance shop owner told me he does that occassionally when a car he builds runs into the smallest little hitting..just barely heats and pries it away....
Old Aug 17, 2006 | 05:44 PM
INMY01TA's Avatar
Loosen header bolts and use a dremel on the K. What kind of headers?
Old Aug 17, 2006 | 05:51 PM
Order 66's Avatar
Try to lossen the header bolts first and have some one push the header up away from the k member and retighten the bolts. That should do the trick.
Old Aug 17, 2006 | 06:48 PM
radz282003's Avatar
Try that first. I had that problem too, on two sets, two different cars. QTP advises the bolt holes are a little larger to compansate for this, so try it first. If not, I suspect grinding in that area won' t hurt. I used my Dremmel and a cutoff wheel to cut a square, and then a carbide bit to shape the opening to fit the primary. It was not that bad. After grinding, I cleaned the area, primed it, and flat blacked it. You should be okay though. That area is boxed, in a way, and I doubt it will effect anything overtime. I would' ve expected better, for the money, but, these cars are built with a high degree of tollerances, so, this kinda' thing should be expected. Every LT seems to have had similar problems, from time-to-time, so don' t get too frustrated.
Good luck.
Old Aug 17, 2006 | 06:53 PM
LS1Lust's Avatar
my qtp headers did the same thing. my friend and i ground away at the k-member then dented the primary. mad them on for a few months and still no contact to this day. good luck
Old Aug 17, 2006 | 08:18 PM
Build #1's Avatar
Good luck.
About the cars built on high tollerances, I agree totally. I will try the loosening bolt method first. I already tried bending it, but thats impossible with out heating the primary. The feed back is greatly appreciated. I have QTP's, noted in my signature.
