Best Way to Clean A Set or headers ??
Old Aug 20, 2006 | 08:06 AM
jwitt2's Avatar
Default Best Way to Clean A Set or headers ??
I had a power steering fluid leak from the rack and pinion.. Left the bottom of my long tubes damn near black... anyone have any ideas of how to het this off or will i have to get them re coated???
Old Aug 20, 2006 | 10:56 AM
slow trap's Avatar
i would say use some scotch brite.they are pads about 6"wide by 8" long and come in a couple different grits.they are great for polishing and slight rust removal.i can't remember where all you can get them,probably at some hardware store i guess.
Old Aug 20, 2006 | 11:11 AM
fast377's Avatar
Maybe throw some break cleaner on there to help break down the grease. Don't know if you will have to recoat them though.
Old Aug 20, 2006 | 11:16 AM
ChocoTaco369's Avatar
Tech Resident
nooooooo no brake cleaner! you may strip the coating. just use a very soft brillo-style pad and some orange clean foaming degreaser. that won't damage anything (but may leave very fine scratches on your headers, not that anyone will really notice).
Old Aug 20, 2006 | 11:45 AM
bluehawk2's Avatar
you could even use sand paper for some of the heavier stains. just treat it like you were water sanding and polishing a car. use the heavier paper(1500 grit) and then sand with 3000. after that use some metal polish-powerball would be nice here and that should get some of the shine back. i got a damn plastic bag hung on my pas side header a few months ago. I had to sand the **** off with 100 grit to get past the plastic. The ceramic coating is usually fairly thick
Old Aug 20, 2006 | 12:34 PM
ski23's Avatar
definitely NOT brake clean. ull eat the coating right off. by some simple green or try some dawn dish soap
Old Aug 20, 2006 | 01:53 PM
Speed Density's Avatar
hashtagBMW
Simple Green. Stuff WORKS! My LTs had oil and dirt burnt on to em. They look brand freaking new.
Tony.
Old Aug 20, 2006 | 02:44 PM
SiL3NtXWS6's Avatar
simple green , and then re-paint them if you wish
Old Aug 20, 2006 | 02:51 PM
BriancWS6's Avatar
Degreaser and then some mothers polish with some SUPERFINE steel wool. Wal-Mart sells it in a bag in the Hardware dept. I have some and it works great for polishing. Go over them again with just a cloth and they should look great.
Old Aug 20, 2006 | 07:37 PM
jwitt2's Avatar
sweet, thanks
