A persistant exhaust leak
Old Aug 24, 2006 | 11:52 AM
99camarosupersport's Avatar
Default A persistant exhaust leak
Ok, so here's the deal. Put new fel-pro gaskets on my car, and for the most part they did take care of my exhaust leak, but when it heats up to ful running temp. the leak comes right back, then goes away BUT it won't do it everytime! Torqued all the bolts down to 25 ft. lbs. The drivers side bolt closest to the front clip is just a loose turn, so i'm thinking the head is stripped. What is your guys opinion, i'm at a loss...do you think putting a heli-coil in or retapping that heads thread will take care of my problem? Any ideas? Pulling up to a stop light with an exhaust leak is quite an embarassment haha.
Old Aug 24, 2006 | 01:55 PM
T T T
Old Aug 24, 2006 | 01:57 PM
Trev_SS's Avatar
try gm gaskets and rethread it
and try it again
Old Aug 24, 2006 | 02:11 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I use the stock gaskets everytime. The fel pro seem to like to burn out and have a crappy seal.
Old Aug 24, 2006 | 02:22 PM
Gearhead1's Avatar
See if you can pull the stripped bolt out and replace it with a stud. There may be enough thread left in the head to do this. Can you tell where it's leaking from?? If it is from around where the bolt is stripped, maybe you could use some high temp silicone on the gasket to keep it from leaking. (something O2 safe, of course) Also, if you have to pull the header off, check the flange surface for flatness. You may have one that is warped for some reason.
Old Aug 24, 2006 | 03:10 PM
TheBlurLS1's Avatar
That's what she said...
Fix the bolt hole (heli-coil or drill + re-tap bigger) and buy some Percy's Seal-4-Good gaskets. Summit sells them for like $30 and they are the nicest gasket's I've ever seen.
I have them on my car with Kooks headers and you can tell just from looking at them that those bitches aren't leaking any time soon. They are dead-soft aluminum and conform to fit as you tighten them down.
Old Aug 24, 2006 | 04:38 PM
Leaking in the center area of the header/head seal. So not close to the loose bolt, i just can't understand why it will heat up and then go away. What is the possibility that my heads have a burnt track in them? Didn't appear so when the gaskets were put on...And as far as buying new gaskets go, i just spent 36$ on these felpro's so new ones are not going to happen. They are what Summit suggested and said they were the best they offered for the LS1. If my header is warped would hooker cover a replacement?
Old Aug 24, 2006 | 09:09 PM
Marc 85Z28's Avatar
Buy some stock GM gaskets and coat them in Permatex's Ultra Copper. You could loose half your header bolts and would still seal. Works great on collector slip fits and turbo downpipes too.
